Old 10-31-2010   #1 (permalink)
the south
11-02-2010 08:54 PM
Time Spent Online: 1 Hour 48 Minutes 48 Seconds
torchred06's album
mechanical question, 97 crown vic
Noticed the other day that to get the car (97 crown vic) out of park I had to stand on the brakes. Problem kept getting worse and now I can't put it in gear at all. Brake fluid and transmission fluid are fine, and no noticeable damage to sensors. Does one of the solenoids on the transnission control this as a safety of some type?
torchred06 is offline Submit to Clesto
Old 10-31-2010   #2 (permalink)
Re: mechanical question, 97 crown vic
I would think so , since you have to mash the brakes to get it into gear . Is there a switch under the dash on the brake peddle ?
Old 10-31-2010   #3 (permalink)
There is a little switch behind the brake pedal that is actuated by you stepping on the brake. This allows a positive current to flow to the brake lights turning them on. The same current flows to the shift interlock allowing you to shift the gear selector out of park.
The most common cause of no brake light-- stuck in park-- is a broken wire at / or close to the connection to the little contact switch behind the brake pedal. Also, The interlock does indeed have a fuse, check your fuse.
If you are in a pinch you can slide the key into the cylinder, turn to the "on" position (NOT run), move the shift lever to N, then start the car.
Old 10-31-2010   #4 (permalink)
the south
11-02-2010 08:54 PM
torchred06's album
Did a little more research. Fuses are all good but I don't have brake lights. Going back out to test the switch now.
Old 10-31-2010   #5 (permalink)
the south
11-02-2010 08:54 PM
torchred06's album
The switch itself has continuity when the pedal is pressed, however there is no power to it. Anyone know where I can get a wiring diagram of the brake circuit?
crown, mechanical, question
Crown Vic Pics. trueblue02 BS Room 15 01-01-2011 04:35 PM
crown vic 302 fr50089 5.0 Mustang 12 07-07-2008 09:05 PM
Mechanical Solution instead of MIL Eliminator's lostsohcs 4.6 Mustang 6 04-29-2007 10:16 AM
'84 Crown Vic WorkingClassSkin BS Room 3 03-28-2007 05:58 PM
Electric or mechanical gauges 19MUSTANG95 Electronics Talk 5 10-19-2006 12:00 PM
