Go Back   Mustangs Insanity > Mustang Tech Department > Suspension/Drivetrain Department > Suspension/Drivetrain Talk
Suspension/Drivetrain Talk Talk about your Suspension/Drivetrain
Old 12-30-2008   #1 (permalink)
Upper control arm sugestions
Well i had the Mustang up on the lift today, just giving her a look over. I noticed the rear upper control arm was rubbing the exhaust pipe. Well i had it adjusted , and when i got home and changed gear oil i noticed it was rubbing again.
I believe a set of after market arms would be better , since the factory ones are stamped and have that lip that sticks out on the bottom. What do you guys think, and what do you reccomend?
Found these on American Muscle . What do you guys think ? http://www.americanmuscle.com/reupcoar7.html
Old 12-30-2008   #2 (permalink)
Re: Upper control arm sugestions
If all of your exhaust hangers and bushings are in good shape, then i would replace the control arms.......and that is a good price on those.
Old 12-30-2008   #3 (permalink)
They're all in good shape. Yeah that's a good price, plus we get a discount and no taxes , or shipping.
Old 12-30-2008   #4 (permalink)
Hellz yea man............I can't wait till i have some money to buy something from them.
Old 12-30-2008   #5 (permalink)
Perf. Driven, Race Proven
ModularSpeed's Avatar
FL/MI
Friends: (12)
12-28-2011 07:34 PM
Time Spent Online: 3 Days 6 Hours 10 Minutes 49 Seconds
Send a message via MSN to ModularSpeed
I kinda like my control arms, but I guess I am bias.
My double adjustable control arms, I retail them for $189.99.....but for Insane members I will do $139shipped.
I also offer the same type of control arms that you have listed, as a complete set with uppers AND lowers for $199 shipped.
'98 N/A Cobra
ModularSpeed is offline Submit to Clesto
Old 12-30-2008   #6 (permalink)
I don't want the lowers just the uppers . I've got my eyes on the Heavy Duty adjustable lowers from Maximun Motorsports. That way i can level out the ride stance. And if i want to lower it more all i have to buy is front springs.
Now those adjustable ones you have look good. How difficult is it for someone that know nothing about suspensions to adjust them?
Old 12-30-2008   #7 (permalink)
03-29-2011 06:09 PM
i have the steeda double adjustable uppers with poly bushings at each end, they definately tightened up the handling and reduced those scary lane changes when you hit bump at full throttle! the only negative thing is i did notice some increased rear axle noise inside the car
Old 12-30-2008   #8 (permalink)
FL/MI
Friends: (12)
12-28-2011 07:34 PM
Not difficult at all!
Old 12-30-2008   #9 (permalink)
03-29-2011 06:09 PM
x2, totally easy!
Old 12-30-2008   #10 (permalink)
2v hater
Real Name: jonathan
jsam's Avatar
frankiln ky
11-17-2013 06:04 PM
Time Spent Online: 3 Days 4 Hours 47 Minutes 53 Seconds
jsam's album
jsam's Garage
i would defenately buy these over the non adj ones you listed
68 coupe, 93 calypso hatch
www.bowlinggreenmustangs.com
control, sugestions, upper
Upper Control arm settings Loadclr Suspension/Drivetrain Talk 8 03-06-2009 02:13 PM
Upper control arms Loadclr Ask ModularSpeed 9 02-12-2009 08:51 PM
Comp Cams upper box? 91stang308 5.0 Mustang 9 11-28-2008 08:27 PM
GT40 lower, upper options? Screw-Rice 5.0 Mustang 8 05-25-2008 01:30 PM
upper control arms silvergt 4.6 Mustang 19 10-24-2007 12:16 PM
