Old 03-08-2009   #1 (permalink)
mustang junkie
Real Name: MARK
mb93gtconv's Avatar
Fountain,co
1 Week Ago 09:45 PM
Time Spent Online: 1 Day 21 Hours 12 Minutes 6 Seconds
mb93gtconv's album
valvetrain adjustment question
first off the motor i have is as follows.
94 302 stock shortblock
anderson ford motorsport b31 cam
twisted wedge heads with stud mount 1.6 rockers.
here is the deal.
i just built this motor.i put the valvetrain on and adjusted it and determined proper pushrod length,got the right pushrods...
so i adjusted all the valves then put the motor in the car,once running i noticed the valvetrain was ticking,so i pulled the valvecovers and readjusted the valves,i put each cylinder on tdc and tightened the adjuster to 0 freeplay,then i turned the adjuster 1/2 turn and ran the lock nut down to touch the stud,then i turned the adjuster and lock nut an additional 1/4 turn to lock it down.put the car back together and started it and a few are still ticking.the top end is getting plenty of oil.is it possible i need to put more preload on the lifters?or does anyone have any other suggestions.i have done this procedure 3 times now and a few are still ticking.i have verified that it isn't the header leaking so that is out of the question.
thanks
mark
2008 Dodge Charger SRT8
69 dodge charger r/t 440,auto.currently under restoration(again)
41 dodge luxory liner.318/auto
mb93gtconv is offline Submit to Clesto
Old 03-09-2009   #2 (permalink)
mustang junkie
Real Name: MARK
mb93gtconv's Avatar
Fountain,co
1 Week Ago 09:45 PM
mb93gtconv's album
Re: valvetrain adjustment question
i did find that one of my pushrod guideplates has excessive pushrod clearance..it is allowing the rocker to move side to side causing a ticking noise.i ordered a new guideplate from summit yesterday and it should be here by friday.hopefully that was my problem.....
Old 03-10-2009   #3 (permalink)
hopefully that takes care of your problem....good luck
adjustment, question, valvetrain
Headlight Adjustment Loadclr Car Care Talk 7 09-21-2009 08:02 AM
Rocker arm adjustment? Nastynotch 5.0 Mustang 1 06-25-2009 10:03 PM
TP Sensor adjustment white90gt Engine Talk 2 06-16-2008 07:51 PM
5.0 Idle Adjustment johnisbubba Mustang Tools 0 02-12-2008 07:22 AM
New valvetrain is here! mezapu 5.0 Mustang 6 09-16-2006 07:13 PM
