Old 06-16-2008   #1 (permalink)
white90gt's Avatar
Ft. Bragg, N. Carolina
06-28-2011 05:05 PM
Time Spent Online: 11 Hours 36 Minutes 2 Seconds
white90gt's album
Unhappy TP Sensor adjustment
I need to know how to test the TPS's postion. I know it needs to be below .999, but i'm not sure what it needs to be above. Also, I need to know where to test it at and what setting to have the multimeter on. Thank you everyone.
white90gt is offline Submit to Clesto
Old 06-16-2008   #2 (permalink)
Here ya go friend:
TPS Adjustment
Old 06-16-2008   #3 (permalink)
618jerrys's Avatar
Glen Carbon, IL
11-17-2011 11:41 AM
Time Spent Online: 18 Hours 9 Minutes 9 Seconds
618jerrys's album
Originally Posted by hotwheels View Post
Here ya go friend: TPS Adjustment
Good info, in addition, I have found the TPS adjustment on a 4.6 can be tricky at times, especially with aftermarket throttle body's. I have ported & polished alot of TB's for the 4.6 (2V & 4V) and found that often the TPS adjustment will not match Ford spec's without some additional work. If you cannot get the correct voltage setting drill the TPS mounting holes slightly larger so that the TPS will rotate more. Additionally, you may find it necessary to slightly bend the idle stop tab on the TB linkage arm. The arm is mild steel and will bend easy, it only takes a few thousandths to make a big difference in idle RPM. Bending the tab outward will decrease idle, however, as noted only a few thousandths is required, you absolutely do not want the TB blade to drag in the housing. To bend the stop tab use a pair of vise grips and pliers. Hold the linkage arm firmly with the vise grips with one hand; and using your other hand with the pliers VERY SLIGHTLY apply pressure to bend the tab. Holding the linkage arm firmly in place with the vise grips will prevent applying sideways pressure that could loosen the arm where it is pressed on to the TB blade shaft.
Ported & Polished Dragon Plenum, TB & Typhoon Manifold. UD Pulleys, Steeda Timing Adj., HyperTech Power Prog., BBK Headers, UPR X-Pipe, Magnaflows, 3:73's, FRPP Lowering Springs, Tolkiko Struts/Shocks, MC-CC Plates
618jerrys is offline Submit to Clesto
adjustment, sensor
Headlight Adjustment Loadclr Car Care Talk 7 09-21-2009 08:02 AM
Rocker arm adjustment? Nastynotch 5.0 Mustang 1 06-25-2009 10:03 PM
valvetrain adjustment question mb93gtconv Engine Talk 2 03-10-2009 07:32 AM
5.0 Idle Adjustment johnisbubba Mustang Tools 0 02-12-2008 07:22 AM
Clutch Adjustment How-To johnisbubba Articles/Archives 0 01-13-2008 01:48 PM
