Old 05-04-2007   #1 (permalink)
Rim size
What is the smallest size rim that I can put 315/35-17 tires on safely. I am wanting two extra rims for DR's. Is the 315/35-17 the tire that will not change my speedo reading. I think that is the one but I am not sure. Thanks in advance for any information. What is the width of my stock wheels.
Old 05-05-2007   #3 (permalink)
I would just try to find a rim setting like this:
Wheel Size: 17x9"
Wheel Backspacing: 5.95"
Wheel Offset: +24mm
Bolt Pattern: 5 x 4.5 inch
That should keep you in the ballpark.
Old 05-05-2007   #5 (permalink)
WyoCobra's Avatar
10-01-2013 10:29 AM
Time Spent Online: 1 Day 3 Hours 14 Minutes 7 Seconds
WyoCobra's album
I would use at least a 9" wheel. A 10-10.5" would obviously work (and look) a little better. A 315/35R17 is the same overall diameter as your stock tires, so your speedo will be on.
WyoCobra is offline Submit to Clesto
exhuast size Demontang Money Pit 17 05-18-2011 01:05 PM
Size does matter!!!!!!!!!!!! JJohnson BS Room 8 02-25-2009 04:30 PM
tire size fit ? poneyexpress 4.6 Mustang 22 06-23-2007 09:16 PM
Help with tire size navyht 4.6 Mustang 6 04-20-2007 07:17 AM
Bore size Screw-Rice 5.0 Mustang 11 02-20-2007 06:09 PM
