Go Back   Mustangs Insanity > Mustang Talk > Mustangs > 6 Cyl (V6) Applications
6 Cyl (V6) Applications Discussions on Ford V6 mustangs
Old 06-03-2010   #11 (permalink)
Real Name: Daryl
dseward's Avatar
Navarre, Fl
10-29-2012 08:28 PM
Time Spent Online: 2 Days 12 Hours 18 Minutes 56 Seconds
dseward's album
dseward's Garage
Re: knock knock
That is all I have for suggestions. Water will create too great of resistance for the engine to crank if it is getting into a cylinder. I hope I am way off base for you. Maybe pull the plugs to make sure there isnt water in the cylinders? you can spin the engine without the plugs in to make sure there isnt water.
dseward is offline Submit to Clesto
Old 06-03-2010   #12 (permalink)
hershy314's Avatar
03-09-2016 04:52 PM
Time Spent Online: 2 Days 11 Hours 26 Minutes 44 Seconds
hershy314's album
Send a message via Yahoo to hershy314
Re: knock knock
i hope ya wrong too, i need to get this car goin so i can sell my other car. i did notice tho that earlier when i was trying to start it i saw some liquid squirting up from the middle of the front of the car. couldnt tell if it was coming from the radiator (which is brand new) or the engine. only liquid i saw was on the pulley for water pump (i think)
hershy314 is offline Submit to Clesto
Old 06-03-2010   #13 (permalink)
Real Name: Daryl
dseward's Avatar
Navarre, Fl
10-29-2012 08:28 PM
dseward's album
dseward's Garage
Re: knock knock
try the plug trick it may be all telling.
Old 06-03-2010   #14 (permalink)
hershy314's Avatar
03-09-2016 04:52 PM
hershy314's album
Re: knock knock
i will try that
Old 06-03-2010   #15 (permalink)
Real Name: Daryl
dseward's Avatar
Navarre, Fl
10-29-2012 08:28 PM
dseward's album
dseward's Garage
Re: knock knock
Let me know what you find. I hope all goes well and it is something simple.
Old 06-03-2010   #16 (permalink)
hershy314's Avatar
03-09-2016 04:52 PM
hershy314's album
Re: knock knock
i will, hope and pray its something easy
Old 06-04-2010   #17 (permalink)
Re: knock knock
if you see liquid on your water pump pulley, check the seep hole on the bottom of the water pump, your pump could be bad now too.
Old 06-04-2010   #18 (permalink)
hershy314's Avatar
03-09-2016 04:52 PM
hershy314's album
Re: knock knock
well i tried the spark plug trick. i pulled a spark plug from each side. drives side had some coolant on it...so im thinkin either cracked head or a blown head gasket. hopefully its the gasket. and the passenger side had a little bit of oil on it. not sure what that could be. probbly not good. starting to think i got a total piece of crap here. oh well life goes on i guess
Old 06-04-2010   #19 (permalink)
Re: knock knock
sounds like a tear down is definately in order.....or go to a scrap yard and pick up a whole 4.6 to drop in it.
Old 06-04-2010   #20 (permalink)
hershy314's Avatar
03-09-2016 04:52 PM
hershy314's album
Re: knock knock
a 4.6 mustang sounds better than the 3.8 that it currently has. i put a pressure tester on the radiator and it held pressure fine. but i heard that sometimes when an engine is cool the leak wont be present till the engine is warmed up. since i cant get it to start its goin to tough to tell if i have a leak for sure. but the coolant on the tip thats in the block seems like a good indicator that i got a leak
knock
LinkBack to this Thread: http://www.insanemustangs.com/forums/6-cyl-v6-applications/17830-knock-knock.html
knock knock - 6 Cyl (V6) Applications This thread Refback 06-02-2010 01:49 PM 2
Acceleration knock Demontang 4.6 Mustang 5 08-31-2010 01:37 PM
Wheel Knock-offs on the 2004 Mach 1 hotwheels BS Room 4 06-18-2010 06:20 AM
Knock Sensor (KS) hotwheels Electronics Tech 0 11-12-2006 12:21 PM
