Go Back   Mustangs Insanity > BS Area > Money Pit
Money Pit
A Place to share pic's and conversations about your ongoing project/s.
Old 06-20-2011   #31 (permalink)
Re: Ta daaaaa!!!!!!
finally got a chance to hit the track with this setup on the car.
old launch 5000rpm with 17" ET streets - 1.83 60'
New launch a soft 3500rpm with the slicks and skinnies - 1.73 60'
car hooked good and the launch was rolling out of the clutch, i think it has more in it for sure, the car bogged off the line. this thing has mid 1.6 60's in it for sure.
Never ran the full pass because it was the first run down the strip in about 18 months and there is a ton of new things on the car. was only working on the launch to start with. was going to go full out on the next pass, but the track closed down due to weather. still made a 14.6 @ 94mph letting out just past the 1000' mark.
Old 06-20-2011   #32 (permalink)
09-25-2013 06:26 PM
Re: Ta daaaaa!!!!!!
Well now you know that it has more in it, so get back to the track when you get a chance and go all out balls to the wall and see what you can do on an overall run.
What RPM are you going to try and launch at now that you know it's bogging at 3500? Good luck bro, and I hope that you stick the launch and pull some good numbers in your ride....
Old 06-20-2011   #33 (permalink)
Re: Ta daaaaa!!!!!!
i figure i will bump it up to 4500rpm and then keep my foot in it through the end. If this 96 gt can pull off a sub 1.7 60' i will be happy. next trip to the track will see the front sway bar removed, after the initial launch the car bucked and jerked cause the front came back down so fast.
Old 06-20-2011   #34 (permalink)
Re: Ta daaaaa!!!!!!
Those are good numbers Brian . I was wanting to take my dad to the track for father's day but it was too hot for him to get out .
I'm hopping I can get similar 60' times out of mine .
Old 06-21-2011   #35 (permalink)
Real Name: Tammy
No1FordGirl's Avatar
Pennsylvania
Friends: (17)
12-06-2012 05:33 AM
Time Spent Online: 1 Week 3 Days 4 Hours 50 Minutes 3 Seconds
Send a message via AIM to No1FordGirl Send a message via Yahoo to No1FordGirl
Re: Ta daaaaa!!!!!!
Keep working at it Brian, you will get it Good luck!
June 2009 ROTM
Count your Blessings, not your problems
No1FordGirl is offline Submit to Clesto
daaaaa!!!!!!
