Go Back   Mustangs Insanity > BS Area > Money Pit
Money Pit
A Place to share pic's and conversations about your ongoing project/s.
Old 09-16-2008   #1 (permalink)
Rear End Girdle.
I am getting ready to install 4.10 gears in the Stang. My question is should I upgrade to a Ford Racing rear end girdle for more strength or is it not needed?
And my second question is do aftermarket coil packs do any good or is it bull?
The best way to meet the Lord is on your knees.
The easiest way to meet him is to trespass.
Old 09-16-2008   #2 (permalink)
Cheyenne Wyoming
12-24-2020 07:58 PM
Time Spent Online: 1 Week 6 Days 7 Hours 49 Minutes 11 Seconds
Re: Rear End Girdle.
Coil packs aren't needed until you have assloads of power. The factory stuff is good. An ignition controller would do you wonders though. Get an MSD or something instead of the coils. Your's are perfectly fine for much higher power levels.
The rear girdle cover is good insurance for the street but is a must at the track. I just got one on my car since I upgraded to 31 spline and plan on some T-brake launches. I used to launch my 28 spline stuff at 5500rpm with the stock cover, a stock T-5, an aluminum DS and a set of 3.73 gears. Others have had the stock stuff break instantly. It's hit or miss. If you have the cash, I'd say get a girdle. I didn't HAVE to before but that's not saying you won't warp or damage anything. It makes draining and replacing fluid easy. You're doing the gears, just get one for the added insurance.
63 Fairlane 4 door
(R&C MII, Vortech Si, 4.6 DOHC/4R70W,8.8")
07 F150 SCREW King Ranch 5.4
Old 09-16-2008   #3 (permalink)
Thank you Dave. I was thinking it wouldn't hurt, but I am getting to the end of the cash flow so I did not want to waste money. It will hopefully hit the track by April of next year with all mods done. I will order a girdle ASAP.
Old 09-16-2008   #4 (permalink)
Friends: (25)
12-07-2013 02:00 PM
Time Spent Online: 1 Week 2 Days 12 Hours 48 Minutes 27 Seconds
whats a girdle?
Old 09-16-2008   #5 (permalink)
Cheyenne Wyoming
12-24-2020 07:58 PM
Coming from you Bobby, I don't know how to read that question. Are you serious or goofing?
Old 09-16-2008   #6 (permalink)
02-13-2012 06:49 AM
Time Spent Online: 4 Days 1 Hour 43 Minutes 52 Seconds
I've broken and seen a lot of rear ends break. From my experience, here's the order that OEM parts will break. Upgrade as you see fit.
- axles, break about 2-3" from the end of the splines
- diff carrier, breaks down the center where the pin goes through
- housing, first the tubes will spin in the center section, next the tubes will twist, lastly the caps will blow off
- never seen a ring/pinion break unless something else breaks first
So, IMO, unless you upgrade the axles and carrier, weld the tubes to the housing and reinforce the tubes, the support cover is not needed. But it certainly won't hurt anything.
Old 09-17-2008   #7 (permalink)
Get it for nothing else but the ease of changeing the fluids, like Dave said. I got the Trick Flow but i guess their all basicly the same.
girdle., rear
Rear End for '02 GT harryfarner BS Room 1 01-02-2012 04:57 PM
To add a stud girdle or not to add a stud girdle white90gt 5.0 Mustang 9 05-09-2010 09:02 PM
Rear end Oil Intmdtr BS Room 3 08-29-2009 10:52 PM
8.8 Rear Diff girdle/cover Loadclr Ask ModularSpeed 12 04-13-2009 12:59 PM
69 rear end Q Demontang Classic Mustangs 1 04-23-2008 06:37 PM
