Old 11-29-2010   #1 (permalink)
02-01-2011 04:36 AM
Time Spent Online: 3 Hours 2 Minutes 11 Seconds
85LXlover's album
Exclamation What is the best cooling set up for a 85 5.0
Im trying to configure the best cooling system setup for my car to ensure it WILL not over heat in traffic. I am looking to replace my entire cooling system, radiator, fan, thermostat, hoses, ect. Hoping i can get some good info from those that know more than i do. thanks for all the help.
85LXlover
85LXlover is offline Submit to Clesto
Old 11-29-2010   #2 (permalink)
01-22-2023 06:05 PM
Time Spent Online: 5 Days 7 Hours 18 Minutes 10 Seconds
jpmcclos's album
Re: What is the best cooling set up for a 85 5.0
I'd guess just a stock water pump, 2-3 row aluminum radiator (I can't remember which for a 5.0), and regular hoses will work just fine. Thermostat, I can't remember which either.
jpmcclos is offline Submit to Clesto
Old 11-30-2010   #3 (permalink)
Real Name: Dave
drkwng306's Avatar
wiconisco pa
01-06-2020 05:05 PM
Time Spent Online: 1 Day 19 Hours 13 Minutes 13 Seconds
drkwng306's album
Yep go with the stock pump summit sells a nice radiator for fox mustangs i think i paid 220 bucks for mine and it works great, polished up nice to. As for hoses stock will work but if you want colors shop around. Carburated go 160 fuel injected go with 180
drkwng306 is offline Submit to Clesto
Old 11-30-2010   #4 (permalink)
definately a 2 or 3 row rad with dual electric fans. 180 degree T-stat. I would also consider switching over to an electric water pump.....
Old 11-30-2010   #5 (permalink)
02-01-2011 04:36 AM
85LXlover's album
ok so heres what i have planned a for the cooling system: a Fluidyne all aluminum 2 core radiator, a high capasity water pump (belt drivin to maintain stock look, a new single flexilite cooling fan with shroud and adjustable settings, and a 180 thermostate, and blue silicone hoses from good year, im hoping with this set up there will be no overheating in my car for the long traffic delays i will encounter
Old 12-01-2010   #6 (permalink)
Sounds like a good set up............
Old 12-01-2010   #7 (permalink)
I hope you have better luck with your Fluidyne then I did . I finally had to take mine to a radiator shop and high temp epoxyed 5 leaks , on the cores where they go into the end tanks .
cooling 1985
cooling system screwed cap (96-98 DOHC) SW modfox 4.6 Mustang 4 03-23-2010 10:52 AM
Cooling Fan hotwheels Wiring Diagrams 0 08-30-2009 06:25 PM
Service Bulletin Number : 17497 (ENGINE COOLING) hotwheels 2004 Ford Mustang TSB's 0 12-02-2006 01:55 PM
Service Bulletin Number : 041601 (ENGINE AND ENGINE COOLING) hotwheels 2006 Ford Mustang TSB's 0 11-24-2006 03:25 PM
