Go Back   Mustangs Insanity > Mustang Tech Department > Electronics Department > Electronics Tech
Electronics Tech No Questions or Posts in here
Old 08-18-2007   #1 (permalink)
Cruise Control Vacuum Dump Valve
1) Remove the vacuum hose from the valve.
2) Remove the valve from the bracket.
To Install:
3) Install the valve to the bracket.
4) Connect the vacuum hose.
5) Adjust the valve.
The vacuum dump valve is movable in its mounting bracket. It should be adjusted so that it is closed, no vacuum leaks, when the brake pedal is in its normal release position, not depressed, and open when the pedal is depressed. Use a hand vacuum pump to make this adjustment.
Cruise Control Vacuum Dump Valve-dumppvalve1.jpg   Cruise Control Vacuum Dump Valve-dumpvalve.jpg
Idle air control valve blackbetty88GT 5.0 Mustang 1 03-27-2010 08:16 PM
Cruise control mustnggt619 5.0 Mustang 1 07-25-2009 05:25 PM
Cruise Control Surges Yellow94GT 5.0 Mustang 6 08-01-2008 04:41 PM
Cruise Control Servo hotwheels Electronics Tech 0 08-18-2007 03:59 PM
troubleshooting cruise control naCAnItIhS 5.0 Mustang 3 06-09-2007 06:52 AM
