Go Back   Mustangs Insanity > Mustang Tech Department > Car Care > Car Care Tech
Car Care Tech No Questions or Posts here
Old 08-31-2006   #1 (permalink)
Mass Air Flow Sensor Cleaning
If you have had bogging or missing or idle spots, about every 25K miles plan on this quick cleaning job:
When your engine is cool, remove the wiring clip from the side of the black plastic sensor part of the MAF aluminum body. To remove the MAF interior sensor wire, you will need a Security Star (Size T15 or T20) screwdriver or screwdriver bit for a power screwdriver. Remove the two security star-head screws and carefully remove the sensor. You will see the two sensor filaments, they look almost like the filaments on a light bulb. Carefully spray the filaments with an O2 safe carburetor cleaner, such as Gumout. Let it dry thoroughly. You can help it along with a careful blast or two of canned dry air. While it is drying carefully wipe the aluminum mount surface of the MAF body if there is any dust there, but be careful not to get dust in the mount hole. When the sensor is dry, replace the sensor back in the MAF body and secure with the security star-head screws. These don't need to be torqued down, just simply hand tight. Replace the wiring clip. Then start up your engine. You should have solved any bogging or missing problems.
Old 04-18-2009   #2 (permalink)
Nelos04's Avatar
05-26-2009 10:47 PM
Time Spent Online: 7 Hours 19 Minutes 18 Seconds
Nelos04's album
Re: Mass Air Flow Sensor Cleaning
I dont' know about the carb cleaner could damage the sensosr,but there is a MAF cleaner now so use that insted. I need to do this my ride has been acting up a lil.
Nelos04 is offline Submit to Clesto
Old 04-18-2009   #3 (permalink)
06-21-2013 03:05 PM
Time Spent Online: 1 Week 2 Days 22 Hours 47 Minutes 45 Seconds
i've used the MAF cleaner and the shit works like a charm.
2002 Mustang GT sold
2010 GT500!!
Old 04-19-2009   #4 (permalink)
Nelos04's Avatar
05-26-2009 10:47 PM
Nelos04's album
yeah it does and it's safe too
Old 05-15-2009   #5 (permalink)
evilernie's Avatar
Portland,OR
08-06-2014 05:40 PM
Time Spent Online: 15 Hours 42 Minutes 59 Seconds
evilernie's album
best way to see if you need it,if yo have a scan tool , you can read the cal load, under full throttle you should be up to or over 100%, if it reads lower the worse the meter is.sometimes cleaning will help but no get you 100%... and no carb clean.. use maf cleaner
evilernie is offline Submit to Clesto
Old 05-15-2009   #6 (permalink)
I have always used carb cleaner on mine. And did just yesterday.
The best way to meet the Lord is on your knees.
The easiest way to meet him is to trespass.
Old 05-30-2019   #7 (permalink)
05-30-2019 08:59 PM
Time Spent Online: 10 Minutes 32 Seconds
drpilot84's album
Recently cleaned mine. Watched a Youtube video and copied what the guy did.
drpilot84 is offline Submit to Clesto
Cleaning out my 5.0 stuff.. NeverEnuff Mustang Classifieds 7 11-10-2011 06:27 AM
Engine Bay Cleaning Beast Mode Car Care Talk 3 09-15-2010 03:25 PM
Window Cleaning Trick!!! southernmustangparts Car Care Talk 44 03-08-2009 06:51 PM
Another expensive mess for Ford: Cleaning up its Twin Cities site hotwheels Ford News 0 08-05-2007 07:22 AM
How about these for Mass Air Flow cfiiman BS Room 15 12-20-2006 05:17 PM
