Go Back   Mustangs Insanity > Mustang Tech Department > Car Care > Car Care Talk
Car Care Talk Ask Car Care Questions Here
Old 09-15-2010   #1 (permalink)
TireSlayer
Beast Mode's Avatar
Winfield, Kansas
01-11-2017 12:11 PM
Time Spent Online: 1 Week 6 Days 4 Hours 30 Minutes 2 Seconds
Beast Mode's album
Engine Bay Cleaning
This can be used on just about every vehicle but these specific instruction's are for 96-present car's.
Start engine, get it warm, not hot, just nice & warm. As an example if the car was fully cooled, run it for 5-8 minute's, turn off engine.
Cover alternator and air filter on intake, Aluminum foil work's great since the engine is warm. Everything else can be subject to light rinsing type spray, lightly spray entire engine bay with water from hose, you will see some light steaming, this is good.
Spray the entire engine bay, including firewall, plastic part's, loom's, coil's and hose's with simple green. Set the hood down, not fully closed, just to it's safety catch point, and go find something else to do for 15-20 minute's. Let the simple green do it's work. Closing the hood let's the simple green interact with the steam you created with the warm engine. This loosen's the tough stuff up so you don't have to work so hard in those heavily soiled area's.
Open hood, look for heavily soiled area's, wipe them with a rag, use more simple green if necessary. Rinse lightly with hose. Spray entire engine bay with F-21, It foam's, coat everything just like the simple green coating. Close hood again, walk away for 10-20 minute's or until nearly all the foam has dissipated open hood, wipe up any area's that water settled and such. Wipe up any area's that the F-21 didn't dissipate on it's own.
You will note that the F-21 restore's the black plastic part's to the same oem flat black color they were when new.. It leave's the paint shiney with no streak's on the fender's and firewall. Best of all, it is not greasy to the touch.
Pleast note that on some other car's you mite have to cover up more part's.
"Get In Sit Down Shut Up and Hang On"
Beast Mode is offline Submit to Clesto
Old 09-15-2010   #2 (permalink)
2000 GT
mknoble91's Avatar
Fond du Lac, Wisconsin
Friends: (17)
07-18-2018 10:51 PM
Time Spent Online: 5 Days 2 Hours 17 Minutes 41 Seconds
mknoble91's album
Re: Engine Bay Cleaning
I'm going to have to try it on my 92 F150, if it cleans that thing then I really will be impressed
Never Quit. Never Surrender. Never Give Up.
Stay Safe. Stay Strong. Stay Positive. #67
Were you born stupid or do you work at it? -67
(without hesitation) I work at it -perp
mknoble91 is offline Submit to Clesto
Old 09-15-2010   #3 (permalink)
Real Name: Rod
Rockford, MN
03-26-2014 12:29 PM
Time Spent Online: 3 Days 51 Minutes 39 Seconds
hellfyr's album
hellfyr's Garage
Coil covers... seal up the coil covers or you will be sorry. Particularly around the back where the harness exits the coil cover cavity. Water can run down in there and seize up a plug in the head... not a fun situation.
Also, I'd recommend sealing up the fuze block and any under hood accessory fuses you have added.
Be VERY thorough in your covering of the alternator (particularly on the cobras) as they are a PITA to change and are weak to begin with.
This is taken from other forums as I have never hosed down an engine in any of my cars, I simply keep up with the cleaning from the time they are new. If an engine bay on a used car is a disaster, I'll pass on buying the car... but that's just me.
Hope that helps!
hellfyr is offline Submit to Clesto
Old 09-15-2010   #4 (permalink)
TireSlayer
Beast Mode's Avatar
Winfield, Kansas
01-11-2017 12:11 PM
Beast Mode's album
Thanks alot Hellfyr I'm no expert and that is good to know I never even thought of that myself. It's also good to know for when I get my 04 Cobra.
cleaning, engine
Mass Air Flow Sensor Cleaning hotwheels Car Care Tech 6 05-30-2019 02:43 AM
Cleaning out my 5.0 stuff.. NeverEnuff Mustang Classifieds 7 11-10-2011 07:27 AM
Window Cleaning Trick!!! southernmustangparts Car Care Talk 44 03-08-2009 07:51 PM
Another expensive mess for Ford: Cleaning up its Twin Cities site hotwheels Ford News 0 08-05-2007 08:22 AM
Service Bulletin Number : 041601 (ENGINE AND ENGINE COOLING) hotwheels 2006 Ford Mustang TSB's 0 11-24-2006 04:25 PM
Copyright ©2000 - 2023
