Go Back   Mustangs Insanity > Mustang Tech Department > Engine Department > Engine Tech > 5.0L
5.0L
If you are looking for information on 5.0 liter engine, you are in the right place. Hopefully we can all learn from each other on how to tune your car for daily driving and how to get the last ounce of performance from your 5.0 liter at the track.
Old 08-19-2007   #1 (permalink)
Stock Rocker Arms Adjustment and Removal
1) Disconnect the negative battery cable for safety.
2) Remove the upper intake manifold assembly. For details, please refer to the intake manifold procedures found later in this section.
3) Remove the rocker arm covers.
4) Except for the Cobra, loosen the rocker arm fulcrum bolt, then remove the bolt, fulcrum (seat), rocker arm and guide. KEEP ALL PARTS IN ORDER FOR INSTALLATION!
Label and/or arrange all rocker arm and fulcrum components to assure installation in their original locations.
5) On the Cobra, loosen the fulcrum bolt, then remove the bolt, roller rocker arm assembly and pedestal assembly.
To install:
6) Inspect the fulcrum bolts for damage. Replace any bolt on which damage is found.
7) Inspect the rocker arm and fulcrum seat or roller contact surfaces for wear and/or damage. Also check the rocker arm for wear on the valve stem tip contact surface and the pushrod socket. Replace complete rocker arm assemblies, as necessary.
8) Inspect the pushrod end and the valve stem tip. Replace pushrods, as necessary. If the valve stem tip is worn, the cylinder head must be removed to replace or machine the valve.
9) Lubricate the rocker arms and fulcrum seats with heavy engine oil or pre-assembly lube before installation.
10) Apply multi-purpose grease to the valve stem tips, the underside of the fulcrum seats and the sockets.
11) Rotate the crankshaft until the tappet is on the base circle of the camshaft lobe (all the way down), then install the rocker arm assembly. Tighten the fulcrum bolt to 18-25 ft. lbs. (24-34 Nm).
12) Install the rocker arm covers.
13) Install the upper intake manifold assembly.
14) Connect the negative battery cable.
Stock Rocker Arms Adjustment and Removal-50cobrarocker.jpg   Stock Rocker Arms Adjustment and Removal-50rocker.jpg
Rocker arm adjustment? Nastynotch 5.0 Mustang 1 06-25-2009 09:03 PM
rocker arms .S.B.D. BS Room 5 05-08-2009 12:21 PM
Clutch Adjustment How-To johnisbubba Articles/Archives 0 01-13-2008 12:48 PM
rocker arms einehund 4.6 Mustang 1 11-27-2007 08:43 PM
Stock H-pipe removal please help burnrubber 5.0 Mustang 2 08-20-2007 11:53 AM
