Old 12-03-2008   #1 (permalink)
Sparky
Went to Seafoam the Mustang this evening and noticed something disturbing. I see a bright blue flash of a spark jumping from the bottom of the wire boot to the block or further down on the base of the plug. Obviously something is not right, but my question is what? Is the plug or the wire bad? The wire is fully seated on the plug and there does not seem to be a miss. So what gives?
Old 12-03-2008   #2 (permalink)
Real Name: kevin
945.0GT's Avatar
san antonio tx
08-10-2011 09:02 PM
Time Spent Online: 3 Days 3 Hours 50 Minutes 5 Seconds
945.0GT's album
945.0GT's Garage
Re: Sparky
cracked ceramic on the plug maybe
945.0GT is offline Submit to Clesto
Old 12-03-2008   #3 (permalink)
Re: Sparky
pull the plugs and look for a burn mark on the ceramic. if none are present them i am guessing cold be your wires. you can take a spray bottle of water and mist the wires...a bright blue spark will be present if you have a bad wire.
Old 12-03-2008   #4 (permalink)
09-25-2013 06:26 PM
Re: Sparky
Yeah I would say try the plug first. Check it for cracks, or like Brian said>>> it will have a brown or black burn spot that will be easy to see on the plug's ceramic.
While it may not miss on that cylinder, if it's jumping fire to the block or something else, it's going to be weak on that cylinder and make the rest of the motor labor to try and compensate.
Old 12-03-2008   #5 (permalink)
QWKPONY
fitz101's Avatar
Indiana
01-09-2014 09:54 PM
Time Spent Online: 2 Days 9 Hours 16 Minutes 45 Seconds
fitz101's album
fitz101's Garage
Send a message via AIM to fitz101
Re: Sparky
*505.6 haha, what they said
1992 Notch Back
2013 Jeep Wrangler Unlimited Sport (don't hate me )
1997 Kawasaki Ninja ZX6R
1976 Honda CB550 (of course it has awesome engine work )
2005 Focus ZX4 ST (KIA Rod through block!)
apple juice $1.39
new shoes $50.00
electricity bill $146.00
Fitz101 deepthroating you in the parking lot of wal-mart ......PRICELESS
Gayer then Einehund
But not as gay as Intmdtr
Which in that case is also gayer then JIB
fitz101 is offline Submit to Clesto
Old 12-04-2008   #6 (permalink)
06-21-2013 03:05 PM
Time Spent Online: 1 Week 2 Days 22 Hours 47 Minutes 45 Seconds
Re: Sparky
you ben drinkin fitz?? you ass. you started before me.
2002 Mustang GT sold
2010 GT500!!
Old 12-04-2008   #7 (permalink)
Re: Sparky
Yup, cracked ceramic or boot......
Old 02-11-2009   #8 (permalink)
Re: Sparky
Finally got around to pulling the plugs and checking on this issue. Didn't find any cracked ceramics, but did find something else. The plugs were the Diamond Fire E3 plugs. The terminal (top were the wire connects) are screw on and were loose. I figure that the vibrations would loosen and tighten the terminal causing the intermitent sparking. Almost all of them were loose. I replaced them with NGK's and the problem went away, idle is better. Also power and throttle response seem improved. I have since talked to someone who said that when you get plug with screw on terminal you should unscrew it, put loctite on it and screw it back on. Oh well, next time. I'm sticking with the NGK's.
Old 02-12-2009   #9 (permalink)
Re: Sparky
Good find , and good choice on the NGK's .
Old 02-12-2009   #10 (permalink)
09-25-2013 06:26 PM
Re: Sparky
Damn I hate those screw on types! They are only good for bikes, and well for unscrewing when you don't need them too!
Good find man.
