Home Register Community History Pictures/Videos Vendors Ford News
Old 04-06-2010   #1 (permalink)
12-28-2017 09:08 AM
Time Spent Online: 4 Days 22 Hours 19 Minutes 16 Seconds
Max HP out of a 4.6 3 valve
What is the max hp you can pull out of a STOCK 4.6 3 valve engine without replaceing the rotating assy and pistons???
Randy Lichty
Old 04-06-2010   #2 (permalink)
10-25-2023 04:26 PM
Time Spent Online: 2 Weeks 5 Days 22 Hours 58 Minutes N/A
Re: Max HP out of a 4.6 3 valve
i guess it depends on if you are going N/A or forced. I think once you start forced induction you are pushing the limits on borrowed time.
But I am not really up on the 3v's so its unknown to me. I have seen 600rwhp 3V's on stock bottom end, but again, for how long?
Old 04-06-2010   #3 (permalink)
12-28-2017 09:08 AM
I was curios I am running a Kenne bell supercharger and can get up to 18 psi but I cannot stick the tires when i put the smaller pully on its about 10 psi Kenne bell says its safe at this with no problems and tells me I am gettin around 500 hp at the wheels this puts my horsepower around 540 to 550 the other pully has to be pushing 625 at the flywheel I would like to use it on the strip but I am afraid it may be too much
Old 04-06-2010   #4 (permalink)
04-13-2023 04:10 PM
Time Spent Online: 4 Weeks 12 Hours 2 Minutes 16 Seconds
I would go with your gut.........If your injectors are stock, maf is stock, etc......you may face going lean and detonating......Especially running those kinds of numbers. 500hp i would think is safe and not much over that unless you upgrade to the above. Don't risk it.......
Old 04-06-2010   #5 (permalink)
03-29-2011 06:09 PM
if kenne bell says 10 lbs is safe i'd stay right there. you may be able to squeeze 12 or 13 but id say 18 is way too much for a stock bottom end. i saw 21 lbs blow the rods out of a lightining and those have a forged factory bottom end
Old 04-06-2010   #6 (permalink)
12-28-2017 09:08 AM
No this is a complete set up new injectors new MAF new aftercooler new throttlebody ect it was also programmed by kenne bell for 5200 feet there is a bit of de rate for this the car does run a bit on the rich side
Old 04-06-2010   #7 (permalink)
Real Name: Daryl
dseward's Avatar
Navarre, Fl
10-29-2012 08:28 PM
Time Spent Online: 2 Days 12 Hours 18 Minutes 56 Seconds
dseward's album
dseward's Garage
Kenne Bell's site quotes about 540 before failures. Clutch was actually first. Unfortunately Ford did the same type build with the 5.0 Coyote (powder pressed rods etc...). I have studied KB a lot and they have very truthful and realistic expectations so if you have done your homework there I would suggest trusting them. My plan is similiar, add the KB for a year until I can afford the lower end rebuild and the clutch; but dont think I wont push it when it comes to power.
I am really happy so far with just the Steeda intake... raced a rice burner that showed me his dyno; 590 hp at the wheels, we ran out of road at about 1/2 mile and I was starting to pull ahead, stock 2010 with just the intake and trac pack. I work with this guy and he has sunk a ton of cash into this car, he was pissed!@!@!
dseward is offline Submit to Clesto
Old 04-07-2010   #8 (permalink)
HBK_2007's Avatar
Riverton, Wyoming
09-15-2010 02:24 PM
Time Spent Online: 18 Hours 2 Minutes 44 Seconds
HBK_2007's album
most places ive seen, 450-500 rwhp is on borrowed time, FI or not
HBK_2007 is offline Submit to Clesto
Old 04-07-2010   #9 (permalink)
Craig Y's Avatar
Las Vegas, NV
12-14-2012 09:44 PM
Time Spent Online: 4 Days 8 Hours 37 Minutes 29 Seconds
Craig Y's album
Craig Y's Garage
I would highly recommend that you listen to the guys at KB, when I put the blower on my girlfriends 06 GT I was told 8 to 10 psi max on a stock lower end....18 psi and you will be getting your new bottom end sooner than you wanted it.
Craig Y is offline Submit to Clesto
Old 04-07-2010   #10 (permalink)
12-28-2017 09:08 AM
yea you probably right there problem is with that bottom end i will also get a new block heads ect cause they useally just explode
valve
AOD valve body mustangfury86 Transmission Talk 8 10-18-2010 07:09 AM
PCV valve Mr. K's Stang 5.0 Mustang 3 04-10-2009 09:24 PM
2-Valve to 4-Valve Swap 4.6 johnisbubba 4.6 Mustang 5 12-07-2008 07:08 PM
Eaton on 2-Valve 4.6..... johnisbubba Mustang Modding 13 04-24-2008 02:15 AM
Valve Body Loadclr Transmission Talk 5 03-31-2008 07:35 PM
Copyright ©2000 - 2024
