Go Back   Mustangs Insanity > Mustang Tech Department > Suspension/Drivetrain Department > Suspension/Drivetrain Talk
Suspension/Drivetrain Talk Talk about your Suspension/Drivetrain
Old 02-10-2010   #1 (permalink)
Bobbys97R
Friends: (25)
7 Hours Ago 12:08 AM
Time Spent Online: 1 Week 2 Days 6 Hours 59 Minutes 26 Seconds
Bookworm
Question Brake Fluid temp rating?
Whats a good temp rating on brake fluid for raceing?
Old 02-10-2010   #2 (permalink)
03-29-2011 07:09 PM
Re: Brake Fluid temp rating?
i'm not too sure about a particular number, but from what i've read, any synthetic fluid will perform well
Old 02-10-2010   #3 (permalink)
Real Name: Dave
drkwng306's Avatar
wiconisco pa
09-06-2011 11:47 AM
Time Spent Online: 1 Day 18 Hours 56 Minutes 18 Seconds
drkwng306's album
i am not a cone crusher yet but from what ive read 600 degrees dry boiling point is what they use and synthetic is the way to go. Wilwood, steeda and maxim motorsports have their own lable of the good stuff
drkwng306 is offline Submit to Clesto
Old 02-10-2010   #4 (permalink)
Bobbys97R
Friends: (25)
thanks I need a degree rating bacause as far as I can tell they wont ship it overseas
Old 02-10-2010   #5 (permalink)
Re Member
Western KS
06-26-2011 07:57 AM
Time Spent Online: 1 Day 10 Hours 43 Minutes 36 Seconds
lostsohcs's album
Minimum dry boiling point on DOT 3, the stuff that came from the factory, is 401 degrees F. DOT 4 is 446 degrees F. DOT 5 is 500 degrees F. DOT 5.1 is 518 degrees F. The wet boiling point drops to 284, 311, 356, and 375 respectively. These are the minimums that each brake fluid must achieve in order to earn its rating. Many manufacturers beat these numbers, but these are the standard. The important thing that I have found is to keep brake fluid fresh. When you see the drop in wet temperature versus dry you understand why road racers bleed their brake system before every race. I have run fresh Castrol GT LMA which (exceeds DOT4) on a road course in the rockies with lots of tight turns and brake use without any boiling problems. I probably couldn't do that if it was a year or two old.
lostsohcs is offline Submit to Clesto
Old 02-10-2010   #6 (permalink)
it can vary from one MFG to another and some MFG's have many different apps of fluid.
Motul has a race fluid with like 595 *F dry and wet of 421*F
their 5.1 is like 520*F dry and 365*F wet.
its "expensive" for brake fluid but it really works well. we ran the "Race fluid" in our dirtbikes. reduced brake fade GREATLY. made a BIG difference !!!
when I install the new 93cobra master/booster and add the 4 lug rear discs it WILL be filled with a high quality race brake fluid.
Old 02-10-2010   #7 (permalink)
Real Name: Rod
Rockford, MN
19 Hours Ago 12:49 PM
Time Spent Online: 2 Days 22 Hours 30 Minutes 19 Seconds
hellfyr's album
hellfyr's Garage
I boiled the DOT3 brake fluid at the Road Course.
Switched over to Amsoil Hi-Temp 600 Brake Fluid.
There is also a product called ATE-SuperBlue
If you alternate between the products for each fluid change (should do it at least yearly if you're racing) it makes it easy to see when you have bled out to the new fluid at each corner. ATE makes a Non-Blue fluid as well if you want to stay with 1 manufacturer.
Rod
hellfyr is offline Submit to Clesto
Old 02-10-2010   #8 (permalink)
Real Name: Joey
92NOTCH's Avatar
Montpelier
Joey Dohner
Joey Dohner
01-03-2011 02:58 PM
Time Spent Online: 1 Day 20 Hours 32 Minutes 14 Seconds
92NOTCH's album
92NOTCH's Garage
Some of the shit i would never think of!!! I never thought about it but i guess it makes alot of sence. That is why i like this site never know what your going to find out next.
Joey 92Notch
92NOTCH is offline Submit to Clesto
Old 02-22-2010   #9 (permalink)
Bobbys97R
Friends: (25)
thanks guys!
brake, fluid, rating?, temp
Fluid chrajohns0 Transmission Talk 10 05-01-2010 08:31 PM
Fluid? bobbys97R Transmission Talk 5 10-11-2009 08:32 PM
Fluid Change for the T-45 crossland5 4.6 Mustang 10 12-03-2008 11:54 PM
My Cobra is eating fluid JayDPee 4.6 Mustang 7 04-04-2007 12:09 AM
Moody's cut Ford credit rating SpdBoss Ford News 0 09-25-2006 04:01 PM
