Go Back   Mustangs Insanity > Mustang Polls > InsaneMustangs Polls
InsaneMustangs Polls Poll's Related to InsaneMustangs
View Poll Results: March 2010 Ride of the Month Poll
vonblinden22 2008 Ford Mustang GT 5 10.20%
Sweet '83 2003 Ford Mustang Cobra 14 28.57%
silvergt 2000 Ford Mustang GT 3 6.12%
BaddBullitt 2001 Ford Mustang GT 14 28.57%
SW Modfox 1979 Ford Mustang 11 22.45%
945.0GT 1994 Ford Mustang GT 2 4.08%
Voters: 49. You may not vote on this poll
Old 03-29-2010   #21 (permalink)
Sweet '83's Avatar
Ludlow, New Brunswick Canada
11-23-2011 09:25 AM
Time Spent Online: 2 Days 4 Hours 48 Minutes 55 Seconds
Sweet '83's album
Re: March 2010 Ride of the Month Poll
Originally Posted by bobbys97R View Post
So whats all done to your car?
Your joking, right??
If Not...Then here you go.. What is below, is the same info that is in the link to my car in the beginning of this poll.
What I was trying to say above was, its hard for me to vote for other rides when there is little or no info and very few pics?? One car in particular I really like is SW modfox with his 4V powered '79, but there is little info and only a couple of pics???
Engine- 4.6L DOHC S/C V8
-Completley stock longblock excluding the Supercharger
-2.8H Mammoth Kenne Bell Twin Screw Supercharger Kit
-The following Fuel system upgrades:
-Dual Focus Pumps
-Kenne Bell Boost-a-Pump
-72 # RC Fuel Injectors
-Leathal performance Intercooler ice box reservoir
-Complete Metco Pulley kit with interchangeable lower pulleys
Drivetrain-
-T56 with an upgraded 26 spline input shaft
-Spec Twin Disc Clutch
-3:73 Gears
Suspension/Wheels/Brakes...-
-Steeda G-Track Suspension (Stage 1 through 4) Some of which has been quoted by MM+FF's Mag who did the mods.
-Stage 1-Boxed steel subframe connectors, three-point tubular steed strut tower brace, billet aluminum caster/camber plates, and Sport Springs, which lower the car a little over an inch.
-Stage 2-Polyurethane IRS subframe and differential bushings, steering rack bushings, heavy-duty antisway bar endlinks, front sway bar bushings, and superfly billet sway bar mounting brackets. For the upper rear subframe mounts. Also included are Steeda's innovative anti-bumpsteer kit (which relocates the pivot point of the outer tie rod so that toe angle does not change during compression of the front suspension) and Steeda's trick X2 lower ball joints
-Stage 3- Incuded in this stage are world-class Bilstein dampers all around, which are an improvement to even the original Bilsteins that came from the factory on all '03-'04 Cobras. Next up is Steeda's own lower G-Trac brace that ties the rear of the front crossmember together for improved rigidity. Lastly, Steeda's innovative 1.375-inch tubular front antisway bar with spacer kit rounds out this stage.
-Stage 4- Includes a steel IRS differential cover brace, polyurethane bushings for the rear control arms, and offset front control arm bushings for more caster and subsequently, more camber gain as the wheel is turned.
-Wheels
18" Anthracite FR500's, dished 18x10's out back with Nitto 285s, up front it has 18x9"s with Nitto 275's
-Brakes- (Mostly stock)
13 inch Brembo drilled and slotted rotors up front and 11 inch brembo's out back.
Exhaust-
- Magnaflow Catted X-pipe
- Mac Cat-back with 3.5" polished rolled tips
Exterior-
-Dark shadow Gray paint
-HID Foglights
-Functional Heat extractor hood vents
-Window tint
-Shelby snake emblems installed by a previous owner, I plan to switch back to the factory snakes
Interior-(Mostly Stock)
-Aeroforce Intreceptor Gauge mounted on the steering column
-Shift light mounted in the dash
Performance-
-This car has made 643 RWHP when it was tuned by Mustang Magic in New York
-The street tune now makes 590 RWHP on 91 octane on 15 PSI and was tuned by Performance Dyno in Concord, NH. This a very concervative tune and this car is capable of sustantially higher numbers, I know. Plans are in the works to turn up the wick in the spring...
-11.1 @ 127mph
This Cobra's History-
As some of you may know this car started its life out in Ontario California back in the spring of 2003. It was purchased and owned by a Lady up untill May of 2008 when it was purchased to be Muscle Mustangs and Fast Fords magazine to be there project vehicle where it served them well and was featured in 5 different issues. It changed hands once after that before I purchased it in September of 2009...
More Photos...I will get some better ones this summer now that I have my new Nikon D5000 camera.
Some Video...
In car..
YouTube- '03 KB Cobra in car
At the track...
Sweet '83 is offline Submit to Clesto
Old 03-29-2010   #22 (permalink)
Friends: (25)
12-07-2013 02:00 PM
Time Spent Online: 1 Week 2 Days 12 Hours 48 Minutes 27 Seconds
damn that thing is fast!
Old 03-30-2010   #23 (permalink)
Wow this is a tight one . Good luck guys .
Old 03-30-2010   #24 (permalink)
This Bullitt is BAD!!
Real Name: Mark
BaddBullitt's Avatar
Milton , Ontario , Canada
Friends: (13)
01-07-2013 03:30 PM
Time Spent Online: 1 Day 10 Hours 59 Minutes 6 Seconds
I can watch that video from:41 to :58 about a million times and never get sick of hearing that Kenne Bell..lol..
Kenne Bell 2.1 439RWHP & 432 Torque.
April 2010 ROTM Winner!!!
http://www.youtube.com/watch?v=AHjmGwZTbBE
http://www.youtube.com/watch?v=w8qVx1t7v4g
BaddBullitt is offline Submit to Clesto
Old 03-30-2010   #25 (permalink)
Craig Y's Avatar
Las Vegas, NV
12-14-2012 09:44 PM
Time Spent Online: 4 Days 8 Hours 37 Minutes 29 Seconds
Craig Y's album
Craig Y's Garage
voted....good luck....nice group of rides
Craig Y is offline Submit to Clesto
Old 03-31-2010   #26 (permalink)
Sweet '83's Avatar
11-23-2011 09:25 AM
Sweet '83's album
Originally Posted by Intmdtr View Post
This poll will close on 04-01-2010 at 01:11 PM
Brian I thought you were in the Mlitary??
Would it not be 13:11 ??
Old 03-31-2010   #27 (permalink)
Stroked and Blown
Real Name: Eddy
armyed's Avatar
Atlanta
Friends: (9)
03-06-2015 11:48 PM
Time Spent Online: 5 Days 8 Hours 10 Minutes 49 Seconds
armyed's album
armyed's Garage
Send a message via AIM to armyed Send a message via Skype™ to armyed
Hahahaha LOW BLOW!
1995 Mustang, Vortech SQ at 15#, Holley Systemax Intake, Edelbrock Vic Jr. Heads, Tremec Tranny Etc Etc Etc.
Website:
http://er637383.gotstang.com
armyed is offline Submit to Clesto
Old 03-31-2010   #28 (permalink)
I just thought the Canadian military did it differently...............lol
Old 03-31-2010   #29 (permalink)
09-26-2018 04:26 AM
Time Spent Online: 2 Weeks 5 Days 22 Hours 27 Minutes 14 Seconds
it would be, but i copied it right from the poll box above. head you of lifted your head away from my avatar to look you would have seen it yourself......
Old 03-31-2010   #30 (permalink)
So it's Doug's fault?............lol
FYI....When I looked just now, it said 11:11 not 13:11 or even 01:11.
Just messing with everyone............lol
2010, march, month, poll, ride
LinkBack to this Thread: http://www.insanemustangs.com/forums/insanemustangs-polls/17356-march-2010-ride-month-poll.html
March 2010 Ride of the Month Poll - InsaneMustangs Polls This thread Refback 03-27-2010 10:12 AM 1
March 2010 Ride of the Month (Sweet '83) hotwheels Ride of the Month 8 05-09-2010 06:24 PM
March 2009 Ride of the Month Poll hotwheels InsaneMustangs Polls 39 04-06-2009 07:52 AM
March 2008 Ride of the Month Poll hotwheels InsaneMustangs Polls 36 04-01-2008 05:13 PM
March 2007 Ride of the Month Poll hotwheels InsaneMustangs Polls 63 03-08-2007 07:28 PM
March 2007 Ride of the month poll is up hotwheels BS Room 3 03-01-2007 12:23 PM
