Old 02-11-2008   #1 (permalink)
Discovery Bay,CA
12-06-2009 01:23 AM
Time Spent Online: 6 Hours 26 Minutes 43 Seconds
Stroker or super charger
If i go with a n/a stroker i know it will probally be more reliable,but only see around 400 maybe 410 rwhp this on a 03 mach1, so wich cams would you recommend this car is mostly street and afew track day events a year just for fun...
-------- added 2 Minutes and 3 Seconds later --------
As for the supercharger i was thinking either Vortech or kennebell with forged rods and pistons...
Last edited by 1fast03mach; 02-11-2008 at 11:19 PM.. Reason: Automerged Doublepost
1fast03mach is offline Submit to Clesto
Old 02-12-2008   #2 (permalink)
11 Hours Ago 04:59 PM
would this be your final engine MOD or a start? i would go with the stroker first...then add IMO a KB Blower.
Obviously with a stroker kit your going to give yourself better performance in N/A applications, but with a Blower only you will be limited to what your motor can handle.
Old 02-12-2008   #3 (permalink)
3 Weeks Ago 10:49 AM
I may be Dumb to the subject but that's what i was kinda planning on doing in phases. Stroker first,later and the blower. Will this not work ?
Old 02-12-2008   #4 (permalink)
09-18-2011 11:13 PM
Time Spent Online: 1 Day 4 Hours 18 Minutes 40 Seconds
How many ponies do you plan on putting to the ground.
Old 02-12-2008   #5 (permalink)
not too jack the thread but ya, you can go either way.
Old 02-12-2008   #6 (permalink)
09-18-2011 11:13 PM
To be honest whats wrong with an Termie engine? They are factory bad ass engines. I May go this route in the next year or so.
Old 02-12-2008   #7 (permalink)
4 Days Ago 04:35 PM
Time Spent Online: 2 Days 2 Hours 31 Minutes 26 Seconds
I would stroke it,port the heads,add cams over putting a blower on the stock shortblock. If yours cars a manual,you do have a steel crank already though. So rods and pistons,and you could run a shitload of boost. Cant go wrong either way.
Old 02-12-2008   #8 (permalink)
go baby go
svtsilversnake's Avatar
springdale, arkansas
04-08-2009 09:00 PM
Time Spent Online: 2 Hours 24 Minutes 7 Seconds
Send a message via AIM to svtsilversnake
do both lol
svtsilversnake is offline Submit to Clesto
Old 02-12-2008   #9 (permalink)
4 Days Ago 04:35 PM
Found this post on modularfords
There is a lot of different ways to get a stroker from these motors, many of them not being optimal. Just be careful and do your research. We have been using a stroker in our race car for 5+years now with great results.
We have done strokers for 96-07GT's, 96-04 Cobra's, Machs, etc... Just a stroker with stock heads & cams will probably make 15-20rwhp 20-30rwtq. If you do heads & cams I have seen 385-400+rwhp depending on compression & intake. Then a stroker with heads & cams will make incredible power with some boost on it. We just did one in an 03 Cobra with twins that made 700rwhp on 93 octane with 10 psi of boost and @ 14-15psi it made 835rwhp. Which goes with the theory that on an efficient engine at 14.7psi you double the N/A HP.
Manny @ HPP Racing (972)395-9844
www.hppmotorsports.com
White 99 Cobra with blue flames. 8.00@179 on true 10.5" slicks and 8.30@168 on radials, soon to be 7's on both.
03 Sonic Blue Cobra; Eaton=476rwhp 496rwtq , N/A = 305rwhp 287rwtq , Twin GT35R's = 820rwhp @ 19 psi. 10.10@137 weighing in @ 3800lbs on 17"s.
302" stroker makes 1,012rwhp 0n 20-21 psi. or 975rwhp @19 psi.
Old 02-12-2008   #10 (permalink)
09-18-2011 11:13 PM
Good post ^
Drive Belt Config with Super Charger maxkemp 4.6L V8 Specific 7 03-30-2009 03:59 PM
bought a new induction setup for my 69 charger mb93gtconv Misc. Pic's 0 03-08-2008 06:48 PM
1988 Ram Charger w/360 fuel line question fitz101 BS Room 3 11-07-2007 12:43 PM
Ford Super Duty seeing super sales hotwheels Ford News 0 06-07-2007 06:29 PM
super charger help mustangfury86 5.0 Mustang 4 04-16-2007 09:45 AM
