Old 10-07-2007   #1 (permalink)
Hillbilly on the Hill
hoss's Avatar
Michigan
09-29-2011 07:27 PM
Time Spent Online: 7 Hours 50 Minutes 32 Seconds
hoss's album
hoss's Garage
351W Build, No compression?!
Hey 351W experts...
My buddy is building a 351W for his truck, and we went to fire it up for the first time, and we are getting no compression. Seems to be blowing air out of the intake, and kinda sucking in thru the exhaust (MAYBE?) Quick specs
1974 351W (from a Gran Torino)
Heads from a 302 (from a nice running 1984 lincoln towncar)
Stock bottom end (we replaced the bearings and checked clearances)
Cheap ass "4x4 offroad cam" & lifter set (Summint Racing brand)
Edelbrock intake & carb
headers and flowmasters (last two don't really matter)
I wish i had cam numbers, but i don't think it came with any anyway.
to time the cam, all we did was align the mark on the crank sprocket with the middle mark on the cam sprocket. all valve events seem to be occur at the right time in the stokes (not obviously 180deg off or anything) compression guage yeilds nothing. FLAT ZERO! with #1 @ TDC and both rockers loose, a leakdown test shows some airflow from both intake and exhaust. the head donor ran GREAT, which is why i don't think the valves are leaking bad enought to cause 0psi of compression. with your finger over the plug hole it seems to suck (create a vacuum) rather than blow your finger off during cranking.
I hope it is something simple I am overlooking, but we're stumped at this point. Hopefully someone here can point me in the right direction.
Thanks so much!
-Hoss-
78 Granada: Explorer 5.0 EFI, C-4, 8.8 (3.73 L/S Disc)...
93 CBR600: Two Brothers Pipe, Jetted, -1/+3 gearing, awaiting '05 body conversion...
96 F250HD: 7.3L Powerstroke, ZF5, Valair 900ft/lb clutch, DIY Tymar intake, 3" MBRP downpipe, 4" back to dual 5" stacks, BB FPR Shim, DIY HPOP pressure fooler... Sticks and tunes to come... Daily Driver...
hoss is offline Submit to Clesto
Old 10-07-2007   #2 (permalink)
Check the rocker adjustments again and make sure they are set right......Then i would check to make sure my timing chain is on correctly, i have seen people try to use those fancy ones and get them off just enough to cause the problem you are describing.....
Old 10-07-2007   #3 (permalink)
DARKHORSE's Avatar
cheyenne
2 Days Ago 12:30 AM
Time Spent Online: 2 Days 5 Hours 22 Minutes 45 Seconds
DARKHORSE's album
run that same test with rockers off the head
running single digets in a N/A car is fun!
bret@grandvalleyautoperformance.com
DARKHORSE is offline Submit to Clesto
Old 10-07-2007   #4 (permalink)
DARKHORSE's Avatar
cheyenne
2 Days Ago 12:30 AM
DARKHORSE's album
so true..........
Old 10-07-2007   #5 (permalink)
13 Hours Ago 04:59 PM
is the cam lobes to tall for the valves? sounds like they are not seating properly.....just another angle. i had a prob like that years ago, tried to go wild on the cam but with a set of stock heads just didn't cut it.
Old 10-07-2007   #6 (permalink)
Just Insane
Real Name: Gary
Justafordguy's Avatar
13 Hours Ago 04:43 PM
Time Spent Online: 2 Days 11 Hours 3 Minutes 47 Seconds
I would say it's cam timing or the push rods are too long.
80 Hatch, 351W, built C4, 2600 Stall
70 Coupe, 351W, Auto, PS, PDB, AC
77 Bronco, 302, Auto, PS, PDB
05 F-250, 6.0 PSD, 5-speed Auto, 4x4 CrewCab
Justafordguy is offline Submit to Clesto
Old 10-08-2007   #7 (permalink)
hoss's Avatar
Michigan
09-29-2011 07:27 PM
hoss's album
hoss's Garage
Thanks guys! we pulled the front end off and found out that the 2 guys that put the timing chain on had it WAY off. I was kind of suspicious while it was still on the stand, but my buddies insisted they had it right. got the cam in time and we have compression now! I knew it couldn't be anything too horrible. We'll have to see how she runs...
Thanks again guys!
-Hoss-
Old 10-08-2007   #8 (permalink)
Right on man.........
Old 10-08-2007   #9 (permalink)
good to hear ya figured it out
11 to 1 compression mini starter jsam Mustang Classifieds 1 03-22-2010 10:05 PM
2.3L Checking Engine Compression hotwheels 2.3L 0 07-12-2008 01:17 AM
Engine Size and Compression Calculator johnisbubba Mustang Tools 0 01-13-2008 08:57 PM
Low compression ratio explained hotwheels Turbo Tech 0 09-01-2006 12:10 AM
Compression testing hotwheels Engine Tech 0 09-01-2006 12:05 AM
