Old 09-19-2007   #1 (permalink)
WhtStng
6 Days Ago 04:47 AM
Time Spent Online: 5 Days 1 Hour 52 Minutes 47 Seconds
Head Help
the TFS 205's, there are 2 diferent ones. one set are the twisted wegde and has 7 degree locks and retainers and the other are the track heat and has 10 degree locks and retainers. everything else is the same......
what diference do those items make on the degree's they are? the link will take you there and you can see what i mean. its on the heads that are assymbled, CNC'd.
http://www.trickflow.com/product/for...Track_Heat.pdf
Old 09-20-2007   #2 (permalink)
They are valve locks. Valve locks are little metal shells that fit in the valve stem groove and wedge in the retainer opening. Without them, the retainer wouldn't stay in position.
Valve locks come in 7* and 10* versions, 7* locks are more then adequate. As you increase the lock angle, you lose clamp strength. This means you give up some wedging action against the lock by the retainer. When this happens, rather than clamping the stem along the keeper groove, more load is transferred to the groove and the little tang inside the lock.
Just a side note, there are no performance gains between the two locks.
Old 09-20-2007   #3 (permalink)
WhtStng
6 Days Ago 04:47 AM
ok so with a power range of 4k-8k rpms and running a solid roller i'd be fine with either?
Old 09-21-2007   #4 (permalink)
Yes, either will work perfectly.......
Old 09-21-2007   #5 (permalink)
Real Name: Jim
J&SPolishing's Avatar
1 Hour Ago 10:50 PM
Time Spent Online: 3 Days 7 Hours 1 Minute 56 Seconds
Personnally if you are going to rev to 8 grand, I would use 10 degree locks with titanium retainers and 7/16 rocker studs unless your going with shaft rockers. Definately use a stud girdle if going with stud mount rockers. 10 degree locks lessen the chance of a valve pulling through the retainer.
If your going with a solid roller, buy your heads bare. You should always match your springs to the cam your running. Go with the springs the cam manufacturer recomends, not a head manufacturer that says good to .xxx lift. Yes, the springs will handle that kind of lift, but what about ramp speeds, could easily go into premature valve float.
J&SPolishing is offline Submit to Clesto
Old 09-21-2007   #6 (permalink)
Minot North Dakota
01-03-2012 10:26 PM
Time Spent Online: 1 Week 5 Days 9 Hours 41 Minutes 28 Seconds
See, I was right. I forgot to mention the bigger studs on the heads though. Good call on those.
93GT = 5.0 & SF feature Nov 05 p60. She's gone but not forgotten......
99 F250 PSD much modded daily driver. Gone too.
63 Galaxie = 4.6 DOHC/4R70W swap. Sitting waiting.
2003 F350 DRW CCLB Lariat 6.0. Current ride for the toy hauler.
Old 09-21-2007   #7 (permalink)
WhtStng
6 Days Ago 04:47 AM
werd, i talked to a race shop here locally today and he told me the same. buy the vic jr's bare and let him build them and pick out a custom cam so he can match it all.
he said he'd do power range from 4-8k and match everything for that rpm range and solid roller cam. oh and the custom cam will be an isky cam if i go through him.....
heads are 450 each bare, solid roller cam 275, solid roller lifters 475, and so on for the rest of the stuff. not sure what exactly he has in mind but i know he does excelent work.
yes stud mount rockers and i still have to get a girdle for the bottom end as well.
who's stud girdle should i go with?
351 Head project fitz101 BS Room 15 04-01-2009 10:48 AM
Head swap patrick05gt 4.6 Mustang 6 04-04-2008 07:04 AM
so i got the rep head lights the other day svtsilversnake BS Room 8 10-22-2007 09:56 PM
Ok got a head question bobbys97R BS Room 2 09-04-2007 01:05 PM
Head Q's Demontang Engine Talk 8 02-01-2007 01:57 PM
