Old 04-30-2010   1 links from elsewhere to this Post. Click to view. #1 (permalink)
farny21's Avatar
big rapids, michigan
10-26-2010 11:23 PM
Time Spent Online: 11 Hours 46 Minutes 21 Seconds
farny21's album
Intake gasket leak
I fired up the 331 for the first time today but as i was putting fluid in it for the first time it started leak around the intake and head and than ran it for a few then it leaked at the driverside rear, so its the passenger side front and dr side rear. it has 289 hipo heads on it with a gt-40p intake and used 97 exploder intake gaskets, do i need to use 289 gaskets or i also plugged my heater core outlets on the pump, do i need to conect the two?
88 5.0 hatchback,
gt-40p exploder motor,
24lb injectors, 70mm throttle body,
76mm mass air, 3.73 gears, eaton posi,
moser 31 spline axles,
scat 331 in the making!!
farny21 is offline Submit to Clesto
Old 05-01-2010   #2 (permalink)
2v hater
Real Name: jonathan
jsam's Avatar
frankiln ky
19 Hours Ago 09:05 AM
Time Spent Online: 3 Days 59 Minutes 16 Seconds
jsam's album
jsam's Garage
Re: Intake gasket leak
yes connect the two nipples on the water pump and using used intake gaskets wtf?????????????
68 coupe, 93 calypso hatch
www.bowlinggreenmustangs.com
Old 05-01-2010   #3 (permalink)
farny21's Avatar
10-26-2010 11:23 PM
farny21's album
found the problem cant use 5.0 gaskets have to use 289 gaskets and thanks for the nipple info?
Old 05-02-2010   #4 (permalink)
farny21's Avatar
10-26-2010 11:23 PM
farny21's album
have another problem, theres white foam in the oil filler neck which i would think is coolant but theres none in the pan and the puke tank is smoking when its up to temp but it runs well to be a head gasket, might have bad heads!
gasket, intake, leak
LinkBack to this Thread: http://www.insanemustangs.com/forums/engine-talk/17607-intake-gasket-leak.html
Intake gasket leak - Engine Talk This thread Refback 04-30-2010 09:27 PM 1
Oil leak? Try this. Loadclr BS Room 2 09-30-2009 09:37 PM
Pesky little oil leak poneyexpress 4.6 Mustang 7 02-19-2009 06:55 AM
Leak?? Kendar 4.6 Mustang 3 01-06-2008 08:11 PM
Im about to blow a gasket. johnisbubba Rant Room 10 12-24-2007 03:59 PM
