ModularSpeed.com
Old 11-29-2009   #1 (permalink)
Ventura, CA
3 Weeks Ago 09:45 PM
Time Spent Online: 1 Day 4 Hours 19 Minutes 26 Seconds
Throttle buggy?
Hey guys, does this bother any of you too?
As you may know, I have the 2010 GT with the 4.6L and 5-speed.
Whenever I shift, the engine revs slightly, sometimes only a couple hundred RPM, sometimes more.
I've even done the experiment completely lifting my foot away from the pedal during the shift, but it still revs.
Does anybody else have this problem? Yes, I know how to shift, been driving a myriad of vehicles, mostly all with manual transmissions, for years. This is the only one that has done this. This is my 3rd car with drive-by-wire throttle too, so it's not technique vs. technology.
Will a tune help with this? It's really annoying!
Any help would be greatly appreciated!
Thanks,
Paul
Stang-n-Vette is offline Submit to Clesto
Old 11-29-2009   #2 (permalink)
1 Day Ago 06:27 AM
Time Spent Online: 1 Week 1 Day 16 Hours 52 Minutes 32 Seconds
Re: Throttle buggy?
is it durning the downshift or the upshift? cause i've seen on a couple of cars now when you go to downshift the computer automatically adjusts the revs to match the gear you are going to go in to...
Waterboarding isn't torture... It's just a hardcore baptism to wash the Islam away!
Old 11-29-2009   #3 (permalink)
Ventura, CA
Re: Throttle buggy?
I haven't paid attention to the downshift part, but I'm pretty sure it doesn't. Only on the upshifts.
Doesn't matter either if I'm aggressively accelerating or mildly accelerating. And there's seeming no "preset" that it's trying to go for, it just increases the engine's rpm.
Sometimes just a few, sometimes a lot. Also between all the gears.
No rhyme or reason, it just revs.
Old 11-29-2009   #4 (permalink)
Friends: (411)
1 Hour Ago 04:27 PM
Time Spent Online: 3 Weeks 1 Day 14 Hours 9 Minutes 9 Seconds
Re: Throttle buggy?
My 95 does that..........not sure why. I thought maybe it was a vacuum leak, but after checking, i found none.
Old 11-29-2009   #5 (permalink)
Gagetown, New Brunswick
Friends: (31)
22 Hours Ago 07:35 PM
Time Spent Online: 2 Weeks 2 Days 15 Hours 51 Minutes 40 Seconds
Re: Throttle buggy?
ok so answer this.....
when you are shifting is the engine under a load like accelerating or are you just cruising along?
If the engine is under a load as soon as you press in the clutch the unsprung load is transfered back to the engine causing it to rev just a little in order (more or less) to release the tension.
try it when you reach an RPM and are no longer accelerating and see if this helps?
buggy?, throttle
Throttle Cable fitz101 BS Room 4 04-20-2009 06:01 PM
Throttle Body LV_Yankee 4.0L V6 Specific 14 02-18-2008 05:33 AM
throttle body? 91stang308 5.0 Mustang 13 02-08-2008 06:16 PM
75mm throttle body Joe02GTBlu 4.6 Mustang 4 01-30-2008 03:40 AM
Throttle cable burnrubber 5.0 Mustang 3 06-15-2007 06:54 PM
Copyright ©2000 - 2010
