Go Back   Mustangs Insanity > Mustang Tech Department > Electronics Department > Electronics Tech
Electronics Tech No Questions or Posts in here
Old 11-12-2006   #1 (permalink)
Barometric Pressure sensor (BP)
The Barometric Pressure (BP) sensor operates as a piezoelectric (pressure-sensing) disc. However, rather than generating a voltage, its output is a frequency change. The sensor changes frequency relative to intake manifold vacuum. The sensor frequency increases as vacuum increases. The BP sensor is used to sense the changes in barometric pressure, allowing the PCM to sense the altitude at which the vehicle is operating. Its signal affects, spark advance for altitude compensation. The BP sensor was only used in early MAF systems. Starting in 1994 Ford learned that air pressure can be calculated once the MAF sensor tells the computer the amount of air ingested by the engine.
Oil Pressure fordracing BS Room 4 07-26-2011 04:46 PM
Which MAF sensor? mknoble91 Money Pit 4 03-18-2011 03:30 PM
Oil Pressure Intmdtr BS Room 4 08-26-2009 09:16 PM
O2 Sensor treman03 4.6 Mustang 3 04-29-2007 08:55 AM
ECT sensor scr_hdb 5.0 Mustang 2 04-12-2007 04:36 PM
