Old 09-04-2006   #1 (permalink)
07-01-2008 04:41 PM
Ghostang99's album
Fuel Pump Relay..HELP!
Does anyone know where I could find the "Fuel Pump Relay" on a 1990 mustang LX 5.0?
Ghostang99 is offline Submit to Clesto
Old 09-04-2006   #2 (permalink)
for replacement or location...........
Old 09-04-2006   #3 (permalink)
I am going to assume you are looking for it's location..............It should be located under the drivers seat...It is mounted to a "T" shaped metal bracket that is bolted to the floor.
Old 09-04-2006   #4 (permalink)
Minot North Dakota
01-03-2012 10:26 PM
Time Spent Online: 1 Week 5 Days 9 Hours 41 Minutes 28 Seconds
Either under the drivers seat or right between the air intake box(if still installed) and the passenger strut tower. If it's under the seat you're golden. If it's in the bay, be careful not to mistake the AC relay. There would be two relays there if it's under the hood.
93GT = 5.0 & SF feature Nov 05 p60. She's gone but not forgotten......
99 F250 PSD much modded daily driver. Gone too.
63 Galaxie = 4.6 DOHC/4R70W swap. Sitting waiting.
2003 F350 DRW CCLB Lariat 6.0. Current ride for the toy hauler.
Old 09-04-2006   #5 (permalink)
12second306's Avatar
08-30-2008 07:08 PM
Under the driver seat
12second306 is offline Submit to Clesto
Old 09-06-2006   #6 (permalink)
07-01-2008 04:41 PM
Ghostang99's album
I found it!!! NOw, for the MOST part , I'm good to go.I turned the key on, checked the voltage to the fuel pump...nothing. Pulled the relay off and checked the voltage there...12v. Did a continuity check on the wire between the relay and the pump...no resistance. Replaced the realy...fired right up! Every now and then, it still acts like it has the same problem, though. There was a goopy build up in the connector to the fuel pump. Hard as hell to get out. Whenever it acts up, I just twist up a piece of paper, clean out the connector, plug it back up, start the car and go. Thanks guys for all the help.
Old 09-07-2006   #7 (permalink)
WhtStng
1 Week Ago 04:47 AM
Time Spent Online: 5 Days 1 Hour 52 Minutes 47 Seconds
good to hear you got it all worked out. hope it starts working better.
Old 09-07-2006   #8 (permalink)
well atleast it's runnin.............anyway you can change the connector or replace it?
Old 04-08-2007   #9 (permalink)
Has the Mustang Bug...
06-20-2008 01:47 PM
to get rid of the goop that is causing the intermittent connection try using some electrical connector cleaner to clean it. . It is available at all auto parts stores. Pick up some dielectric grease to put on the connector and it should fix it permanently and keep it from corroding. .
1 clean notch is offline Submit to Clesto
where is the fuel pump relay on a 89? Beernut 5.0 Mustang 6 06-26-2008 12:40 PM
fuel pump relay location 86notch 4 Cylinder NA and Turbo 6 06-05-2008 05:48 PM
fuel pump? mustangfury86 5.0 Mustang 4 07-03-2007 10:38 PM
Need a new fuel pump jcomolli 4.6 Mustang 0 05-25-2007 01:06 PM
Fuel Pump probelm? Loadclr 5.0 Mustang 18 05-16-2007 09:45 PM
