Old 05-25-2010   1 links from elsewhere to this Post. Click to view. #1 (permalink)
11 Hours Ago 04:59 PM
Hitit
A/C / heater issues.
So now its getting damn hot around here and i wanted to fire on the A/C in the stang, well shit i had nothing, tried the heater, same thing....nothing. I checked all the under dash and under hood fuses and those are all good. when you switch to a/c you hear it do its little exhaust and know its not the switch itself, would a blower motor just shit the bed like that or could it be something else?
Old 05-25-2010   #2 (permalink)
BB90GT's Avatar
3 Days Ago 03:58 PM
Time Spent Online: 4 Days 1 Hour 31 Minutes 26 Seconds
BB90GT's album
BB90GT's Garage
Re: A/C / heater issues.
I blower motor can just shit the bed like that especially if the car has been sitting for a while. But something to check is whether the compressor does anything when you kick the switch on cause the heater cycles the compressor when you turn it on so that the bearing dont go bad over the winter in them. If the compressor does nothing then you may still have a switch issue. The little exhaust you hear is just the flapper door and it may or may not be moving it can always just exhaust the air then stay stuck in place. More than likely you have a switch issues at the dash I would just jumper the switch and see what happens just my opinion though.
LSU TIGERS
BB90GT is offline Submit to Clesto
Old 05-25-2010   #3 (permalink)
Yes the blower motor can just fail........I think the fuse is like number 17 and it's a 30amp. If that isn't shot and the blower isn't working, replace the blower.
Old 05-25-2010   #4 (permalink)
Real Name: Justin
mustangfury86's Avatar
shreveport , la
07-27-2011 11:09 AM
Time Spent Online: 1 Day 1 Hour 9 Minutes 17 Seconds
deffnatly with the blower but have replaced the resistor before 2.
Old 05-25-2010   #5 (permalink)
the car hasn't sat that long, everything worked a couple of weeks ago, and then it sat last week. now to check if its the switch just pull out the switch housing and jumper the wires in the plug themselves? and which wires?
-------- added 1 Minutes and 16 Seconds later --------
oh and when i also turn the switch on, the compressor does cycle. it drops the engines RPMS when i switch to A/C
Old 05-25-2010   #6 (permalink)
Do you have a test light or a meter? If so I would pull out the heater controll and check for power at the fan switch. If you have power there go to the resistors. From the resistors you should have power to the fan. If no power at the fan switch(with key on)trace the wire to fuse box. Don't try to force the switch to work cause you may damage the resistor if it isn't already shot. If it show's you have good connections all the way to the green 30 amp fuse, go ahead and pull the blower and run a couple wires to your battery and see if it will run (becareful when you do this because it will start in high mode, so it will jump on start). If the fan doesn't start, you will have to replace it. If the fan runs, you will have to replace your resistor and switch. You have to do both because if the resistor isn't reducing your electrical current, it will burn up the new swich. Hope this makes sense brian.
Old 05-25-2010   #7 (permalink)
so in a nut shell strip the car down and turn it into a drag car?
Old 05-25-2010   #8 (permalink)
lmao............yes
heater, issues.
LinkBack to this Thread: http://www.insanemustangs.com/forums/electronics-talk/17769-c-heater-issues.html
A/C / heater issues. - Electronics Talk This thread Refback 05-25-2010 02:29 PM 1
Heater core cobra_im 5.0 Mustang 6 07-27-2009 08:51 PM
Giving my GT's AC/heater away Dave R BS Room 0 04-10-2009 08:01 AM
Heater problem? 88five-oh 5.0 Mustang 7 01-02-2009 05:55 PM
heater core ? mustangfury86 5.0 Mustang 17 12-05-2007 04:44 PM
Heater Core hotwheels Electronics Tech 0 08-18-2007 03:14 PM
