Old 05-23-2009   #1 (permalink)
11-08-2009 03:09 PM
Time Spent Online: 1 Hour 20 Minutes 8 Seconds
solenoid sticking
I have a problem with my 1990 mustang gt. I have replaced the solenoid, starter and battery and still the solenoid contacts overheat and stick..
jnickason@yahoo.com is offline Submit to Clesto
Old 05-23-2009   #2 (permalink)
2 Weeks Ago 10:49 AM
Re: solenoid sticking
Welcome to the site . wish i could help but i don't know what to do , other than what you have already done . I would check all my connections on my all the wires .
Old 05-23-2009   #3 (permalink)
Friends: (415)
6 Days Ago 05:22 PM
Time Spent Online: 3 Weeks 6 Days 5 Hours 23 Minutes 13 Seconds
Since you replace the solenoid, starter and battery, you should now check all of your grounds. Mainly the one from the - side of the battery to the block. Make sure it is clean right up against the block and that your actual terminals at the battery are clean.
Sounds to me like you have a bad ground somewhere in the battery to starting system...so be sure to locate and clean all your grounds in the engine bay.
solenoid, sticking
Starter or Solenoid? Loadclr 4 Cylinder NA and Turbo 5 09-09-2009 06:51 PM
Help...Starter/Solenoid wiring diagram needed Novi_5.0 5.0 Mustang 3 08-06-2007 02:58 AM
