Old 03-15-2009   #1 (permalink)
farny21's Avatar
big rapids, michigan
10-26-2010 11:23 PM
Time Spent Online: 11 Hours 46 Minutes 21 Seconds
farny21's album
computer help
When i plug my code reader in it doesnt read anything and it just stays solid red and my tps sensor is not set and the car runs good but i cant seem to get any readings. i think the computer is in default mode but i havent been able to figure it out. help!!!!!
88 5.0 hatchback,
gt-40p exploder motor,
24lb injectors, 70mm throttle body,
76mm mass air, 3.73 gears, eaton posi,
moser 31 spline axles,
scat 331 in the making!!
farny21 is offline Submit to Clesto
Old 03-16-2009   #2 (permalink)
3 Weeks Ago 10:49 AM
Re: computer help
I don't know much about them , but have you tryed calling the manufacture . I hate i couldn't be of more help .
Old 03-16-2009   #3 (permalink)
Re: computer help
Try disconnectiong your battery for 15min to 30min and then reconnect. Drive the car for about 30 minutes so the computer can relearn and try it again.
Old 03-16-2009   #4 (permalink)
farny21's Avatar
10-26-2010 11:23 PM
farny21's album
Re: computer help
still nothing, i dont know if the computers bad or the wires are messed up somewhere in the dash or what. but if that were the case why is it running?could it be a ground, i have no idea.
Old 03-16-2009   #5 (permalink)
14 Hours Ago 01:53 PM
Re: computer help
If your car is running fine, you might have a bad code reader. Also check the batteries in the code reader, they may need replaced.
computer
computer tunning mustangfury86 4.6 Mustang 7 12-19-2009 12:24 AM
5.0 computer ? farny21 5.0 Mustang 4 04-09-2009 07:12 AM
a9l computer wtb farny21 5.0 Mustang 7 04-01-2009 10:55 PM
computer? mustangfury86 5.0 Mustang 0 11-28-2007 10:30 PM
computer help? mustangfury86 5.0 Mustang 2 06-20-2007 09:15 PM
