Go Back   Mustangs Insanity > Mustang Tech Department > 2005 - 2008 Ford Mustang Repair Info > Chassis Electrical > Chassis Electrical
Wire and Connector Repair
Almost anyone can replace damaged wires, as long as the proper tools and parts are available. Wire and terminals are available to fit almost any need. Even the specialized weatherproof, molded and hard shell connectors are now available from aftermarket suppliers.
Be sure the ends of all the wires are fitted with the proper terminal hardware and connectors. Wrapping a wire around a stud is never a permanent solution and will only cause trouble later. Replace wires one at a time to avoid confusion. Always route wires exactly the same as the factory.
NOTE: If connector repair is necessary, only attempt it if you have the proper tools. Weatherproof and hard shell connectors require special tools to release the pins inside the connector. Attempting to repair these connectors with conventional hand tools will damage them.
connector, repair, wire
Wire Harness Under Center Console. plorden 4.6L V8 Specific 4 05-23-2010 08:59 PM
Mass Air connector diagrams Beernut Electronics Tech 0 10-28-2009 08:54 PM
I gonna do a Wire Tuck... 85cobra BS Room 15 05-12-2009 06:55 AM
Spout Connector 19MUSTANG95 Electronics Talk 40 04-02-2009 04:38 PM
burnt a wire now no spark/fuel pump..WTF? Beernut BS Room 20 06-27-2008 07:18 PM
