Old 02-01-2008   #1 (permalink)
08-21-2017 08:51 AM
Time Spent Online: 1 Day 21 Hours 17 Minutes 47 Seconds
Know your enemy...
A little reading to understand our rivals..
1998 F-Body
1. Had different casting heads which had perimeter bolts and valve covers.
2. Ignition coils were mounted to the valve covers one at a time.
3. The water temp gauge actually works.
4. 98's do have an oil life monitor, they just don't tell you anything when its time for a change. You can find it in Auto-Tap
5. WS6s had single outlet exhaust (all others had duals)
6. Steering wheel controls were completely different part with indentations on the buttons, and were better built
7. Only year that Purple, Gold, and Green were available
8. Some very early Trans Ams came with LT1 style headrests
9. Rear hatch release was poorly designed and often caused problems releasing mechanism
10. Early model 98 Monsoon stereos didn't have capability to control 12-disc CD changer
11. 1998-1999 automatic transmission LS1s could be started in 1st gear even with the shifter in 2nd. Starting 2000, if you put the shifter in 2, it would start off in 2, even from a stop.
12. 1998-1999 LS1 cars had a smaller throttle body cam, which caused the throttle to open to WOT (wide open throttle) faster than 2000+ cars
13. 1998 cars had 28 lb fuel injectors from the factory
14. 1998-2000 cars had a larger cam than the 01-02 cars
15. 1998-1999 cars had more restrictive exhaust manifolds
16. 1998-2000 cars had an LS1 intake with EGR
17. 1998 and some early 1999 cars had blue outside rear view mirrors (Trans Am only)
18. 1998 only LS1 blocks had a much smaller cylinder sleeve that only tolerated a .005" hone
19. Last year F-body to use the old 15.5 gallon steel fuel tank.
20. Only year LS1 F-body to contain a gas cap with a tether long enough to actually hang from the fuel door while open
21. Only year LS1 F-body to not contain the famous GM black box used in the event of an accident to record up to 5 seconds of pre-crash data
22. 1998 only cars had a different PCV system with the PCV valve located above the passenger side valve cover
23. 1998 most cars did not have an idle adjustment screw on the throttle body. Some 98 cars do have the idle throttle stop set screws.
24. 1998 cars have a completely different PCM from 99+ cars
25. A production shortage of F-body cams caused the use of a C5 cam to be installed in F-body LS1s for a very short time
26. 97-98 LS1's used a paper water pump gasket. The only gasket that isn't reuseable
27. SSs did not ALL go to SLP starting in 98. Y2Y was the RPO code that sent them to SLP for additional options
28. SS option did not "include" the Synthetic oil package, it was a SLP only Option
1999 F-Body
1. 1999-2000 cars switched to 26 lb fuel injectors
2. Cylinder heads and valve covers redesigned to have center bolts instead of perimeter bolts. Other than that, the heads were the same.
3. Redesigned cylinder sleeves that allowed for a small bore, up from .005" in 1998 models.
4. Midyear model change to a cheaper steering wheel audio control button without finger indentations, and cheaper built
5. 1999 cars continued the LS1 intake with EGR provisions
6. 1999 cars continued more restrictive exhaust manifolds and larger cam
7. Only year that Hugger Orange was available (Camaro only)
8. 30th Anniversary Trans Am available with special blue and white paint package and blue clear coated WS6 wheels
9. Switch to larger 16.8 gallon plastic fuel tank to meet new emissions requirements.
10. Gascap tether was shorter and could no longer be used to hang on the gas door when open.
11. Company wide change added black boxes to record up to 5 seconds of data before a crash
12. Rear hatch release was redesigned with stiffer spring that released the hatch better
13. Water temp gauge was redesigned to work basically as a dummy gauge and only show an overheat condition.
14. An oil life monitor was added to all LS1s, thus changing the gauge cluster a little to show the oil life reset swtich
15. 1999-02 cars had a different PCV system with the valve located to the side of the intake manifold
16. Early production 1999 Trans Ams still had the blue outside mirrors, but a midyear change went to the non-tinted ones
17. 1999 there was the color "Medium Blue Metallic" which was available on both the Camaros and Firebirds. Only one year of that color
2000 F-Body
1. Redesigned exhaust manifolds for new emissions standard actually flowed better and created a little more HP.
2. 2000 continued use of LS1 Intake, EGR, smaller cam, and 26 lb fuel injectors
3. Added rear child seat safety hooks to interior per federal requirements
4. Very early run of WS6s had "salad shooter" style rims. A production change switched back to standard 5-spoke WS6 rims.
5. Camaros got redesigned 10-spoke base rims, and SSs came with new 10-spoke rim design
6. First year of Monterey Maple Metallic paint
7. Charcoal (grayish) interior was replaced with Ebony (almost black) leather interior
8. Cloth interior cars got new rainbow colored cloth patterns
9. Camaros only got the Pontiac steering wheel with optional audio controls
10. Throttle body cam was increased in size to slow the speed at which the car reaches WOT
11. Automatic transmission cars were reprogrammed to allow a car to start off in 2nd gear from a stop when the shift lever is put into 2.
12. The last year a WS6 Formula was offered
13. Starting 2000 intake lids contained a seperate breather filter
14. 2000+ Camaros came with body colored mirrors instead of black ones like 98-99
2001 F-Body
1. A small percentage of 2001 and 2002 LS1s actually had LS6 blocks which had a different part number and a darker metal cast
2. Starting 2001, all LS1s came with an LS6 intake manifold without an EGR system
3. Advertised HP output was changed from 305 to 310 on base LS1s and from 320 to 325 on WS6s and SSs
4. 2001-02 cars have a smaller cam from the Vortec truck engines to increase low end torque
5. 2001-02 cars had 28 lb fuel injectors like the 98 cars (albeit different part numbers)
6. WS6 cars had a redesigned 5 spoke rim which was more wavy
7. WS6 cars got less suspension upgrades from a base Trans Am suspension than previous years
8. Manual transmission cars all came with the Z06 clutch
2002 F-Body
1. 35th Annivesary edition of the Camaro, and Collectors Edition Trans Am available
2. 2002 LS1 head gaskets redesigned. The new ones are a pressed metal, as opposed to the graphite ones and are no longer specific to the side of the car theyre installed on
3. 2002 cars continued with the LS6 intake, 28 lb fuel inectors and smaller truck cam
4. 2002 continued the use of an LS6 block in some LS1 F-bodies
5. A factory supported optional 345 HP option could be ordered from SLP
6. Manual transmission cars continued use of the Z06 clutch
7. Some 2002 model F-bodies came with a revised rear view mirror that had the map light buttons on the bottom, rather than the front.
What is the difference between a T/A and a WS6 and how can I tell if it's a real WS6 or not?
WS6 in general is an appearance and suspension option offered on T/A's and Formula's. SOme common dead giveaways of a true WS6 is the hood and the components that go with it. The airbox is taller than a stock T/A's to tate up with the Ram Air hood. Also the WS6's came with a sportier suspension, ie, decarbon shocks. Badging on the rear is a definate identifier. Besides the badging, the best way to know for sure is the door sticker on the inside of the drivers side door where you'll see the code "WS6"
What's the differences between the years?
In 1998, the T/A was introduced with the LS1 for the first time. These LS1's came with perimeter bolt valve covers instead of centerbolt and the coil packs were not on a bracket but rather individually bolted onto the valvecover. Other noteable differences were larger fuel injecters and the famous OTL exhaust "One on the Left" Where one single exhaust tip exited on the drivers side. The exhaust was a much more free flowing exhaust system than the later years. In 1998 the EGR system was definately present with a tube going directly into the intake manifold. Many either completely delete the EGR or trim the tube going into the manifold to incease the flow of intake.
In 1999, the exhaust because a little more restrictive with the introduction of dual exiting exhaust but smaller piping. EGR was present but they also downgraded the fuel injectors to I believe 26 lbs from 28 lbs. Other than that, the T/A remained relatively unchanged.
In 2000, The EGR was relocated and injectors were stepped back up to 28 lbs from 26. The introduction of an Air tube into the induction lid was also included.
In 2001 and 2002, everything remained relatively the same with the exception of an LS6 manifold instead of the stock LS1 manifold. HP increase by about 10hp. In 01 and 02, some T/A received an LS6 block due to a casting shortage of LS1 blocks. SO if you are curious if you have an LS6 block, below the rear of the drivers side head is a block casting number. If the last 4 digits are 1168, then you've got an LS6 block
Stock 98-00 LS1 cam
Duration @ .050 198.86 intake 209.25 exhaust
Lift .498 intake .497 exhaust
LSA 119.45
Stock 01-02 LS1 cam
Duration @ .050 196.37 intake 208.72 exhaust
Lift .464 intake .479 exhaust
LSA 115.92
That all I can think of at the moment. Feel free to add on to this thread or correct me if I'm wrong. I'm only human not an encyclopedia!
Old 02-01-2008   #2 (permalink)
Blown
04Roush2's Avatar
Killeen, TX
11-28-2011 04:42 AM
Time Spent Online: 1 Hour 50 Minutes 6 Seconds
04Roush2's album
Send a message via MSN to 04Roush2 Send a message via Yahoo to 04Roush2
I still smoke em
04Roush2 is offline Submit to Clesto
Old 02-01-2008   #3 (permalink)
2v hater
Real Name: jonathan
jsam's Avatar
frankiln ky
11-17-2013 07:04 PM
Time Spent Online: 3 Days 4 Hours 47 Minutes 53 Seconds
jsam's album
jsam's Garage
also the so called god of motors (ls1) has junk powder metal rods. imagine that. LOL
68 coupe, 93 calypso hatch
www.bowlinggreenmustangs.com
Allen West: Define the Enemy: What it takes to win in Afghanistan Loadclr BS Room 0 08-04-2010 08:19 PM
