Old 12-06-2011   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Real Name: Randy
04-22-2015 11:43 AM
Time Spent Online: 7 Hours 40 Minutes 59 Seconds
mustang's album
mustang's Garage
Gm one wire alt. in a 93 stang
I need some help i have a 93 coupe i put a 351w in an i have heard u can put a gm one wire internaly regulated altanator in has anyone done this? anyone have wire diagrams?
mustang is offline Submit to Clesto
Old 12-06-2011   #2 (permalink)
02-18-2012 07:50 AM
Time Spent Online: 5 Days 1 Hour 55 Minutes 7 Seconds
I could be wrong but i believe u just run a wire from starter batt post to the alt post and ur done. Granted thats a 0 size cable just like te batt cable. The alt uses the batt voltage to start the process and since the alt makes more power then the batt the batt takes a charge from it.
Thats what im looking at for my ls1 carb swap cause its wire simplicity at its best haha.
Old 12-06-2011   #3 (permalink)
02-17-2014 05:31 PM
Re: Gm one wire alt. in a 93 stang
I wouldn't go with a GM alternator. You can get one of these and it has everything to convert it to a 1 wire. I'm running one on my 91 coupe. I would also get the power wire to go with it.
PA Performance Mustang Alternator - 130 Amp (87-93) 1619 - Free Shipping!
PA Performance Premium Mustang Power Wire Kit (86-04 Mustang) 9902 - Free Shipping!
Old 12-09-2011   #4 (permalink)
2v hater
Real Name: jonathan
jsam's Avatar
frankiln ky
11-17-2013 07:04 PM
Time Spent Online: 3 Days 4 Hours 47 Minutes 53 Seconds
jsam's album
jsam's Garage
i wouldn't do the gm 1 wire. you can get a ford case 1 wire. search ebay there are plenty of them out there. to wire it use a 10ga or bigger wire and run it from the alt to the hot post on your starter soleniod and you are done
68 coupe, 93 calypso hatch
www.bowlinggreenmustangs.com
Old 12-09-2011   #5 (permalink)
04-28-2018 10:44 AM
Time Spent Online: 4 Weeks 11 Hours 40 Minutes 24 Seconds
I put a one wire Chevy on my ford 400 engine and ran the main wire to the solenoid and burnt my electrical stuff up; solenoid, dist, etc. after I sat and thought about what could had caused this, I realized that the alt puts out 14 volts and almost all the engine electronics take 12volts....so I bought all new parts and ran the alt wire to the battery and left everything else the same and haven't had a lick of problems since. I know alt to solenoid will work, but it ended up costing me a ton of cash in the end.
Old 12-10-2011   #6 (permalink)
02-18-2012 07:50 AM
To the batt should work just fine. It uses initial batt voltage to excite the field windongs in the alt and then BAM! it jumps it up to 14 and starts charging.
alt., stang, wire
LinkBack to this Thread: http://www.insanemustangs.com/forums/bs-room/20095-gm-one-wire-alt-93-stang.html
Gm one wire alt. in a 93 stang - BS Room This thread Refback 12-06-2011 02:50 PM 2
47 Ford Door glass installed and front wire wheels installed hotwheels BS Room 11 01-10-2011 05:27 PM
Wire Harness Under Center Console. plorden 4.6L V8 Specific 4 05-23-2010 08:59 PM
Wire and Connector Repair hotwheels Chassis Electrical 0 08-30-2009 03:48 PM
I gonna do a Wire Tuck... 85cobra BS Room 15 05-12-2009 06:55 AM
burnt a wire now no spark/fuel pump..WTF? Beernut BS Room 20 06-27-2008 07:18 PM
