Old 05-02-2011   #1 (permalink)
Real Name: Devin
Demontang's Avatar
Selah Wa
02-08-2018 04:35 PM
Time Spent Online: 2 Days 8 Hours 3 Minutes 41 Seconds
Demontang's album
mild 302+ 4in lift blocks = death
So today I was pulling my small trailer with a light load to the dump and had a little problem. They are doing construction every where down town and I had to pull out across two lanes of heavy traffic which had me using the right pedal a little. Well I jumped on it and felt a bad bad thing happen, after I got out in traffic my bronco was vibrating bad. So I just went home and look under it to see I broke both blocks and bent the spring perches which intern cracked the tubes and caused my driveline to contact the pinion flange. All this from a explorer 302 motor with little else, who ever tells me a 302 dont have torque can . Ive drove the snot out of a bronco with built 400m that was suppost upword of 450ftlbs and I think this 302 is way meaner off the line and I had the same lift/tire size.
Demontang is offline Submit to Clesto
Old 05-03-2011   #2 (permalink)
09-25-2013 07:26 PM
Re: mild 302+ 4in lift blocks = death
Man that sucks. Good thing that they didn't completely shoot out of there!
Old 05-03-2011   #3 (permalink)
Real Name: Devin
Demontang's Avatar
Selah Wa
02-08-2018 04:35 PM
Demontang's album
yea I just cant believe it bent and cracked the axle tubes and spring perch's. Its going to be a spendy fix, so Im driving the 79 f250 now.
Old 05-03-2011   #4 (permalink)
Good luck on the fix.
The best way to meet the Lord is on your knees.
The easiest way to meet him is to trespass.
Old 05-03-2011   #5 (permalink)
04-28-2018 10:44 AM
Time Spent Online: 4 Weeks 11 Hours 40 Minutes 24 Seconds
That sucks man, glad it didn't come apart and cause more damage
Old 05-03-2011   #6 (permalink)
04-21-2015 06:48 PM
You got lucky that time , with the blocks . It would be good if you could find some re-arched springs for it .
Old 05-03-2011   #7 (permalink)
Real Name: Devin
Demontang's Avatar
Selah Wa
02-08-2018 04:35 PM
Demontang's album
I'm looking at removing the blocks and reworking the suspension. I'll have to find a new axle first dont think I'll trust this one now that it's cracked and all that.
Old 05-04-2011   #8 (permalink)
Odd man
Real Name: Joshua
Halfaed's Avatar
Wisconsin
05-15-2012 06:43 PM
Time Spent Online: 10 Hours 42 Minutes 30 Seconds
Halfaed's album
Halfaed's Garage
That's scary!!! You did get lucky!
If you can't fix it with a hammer, it must be an electrical problem.
Halfaed is offline Submit to Clesto
Old 05-05-2011   #9 (permalink)
Real Name: Devin
Demontang's Avatar
Selah Wa
02-08-2018 04:35 PM
Demontang's album
Yes it probly helped that I had put good u bolts on it after I got it. I think the thinner old ones would have snapped.
302+, blocks, death, lift, mild
Shop Lift hotwheels BS Room 9 11-07-2012 06:12 PM
Does anyone here know much about Ford Big Blocks JROC Engine Talk 3 10-04-2008 08:02 PM
4.6 blocks silvergt 4.6L V8 Specific 13 03-09-2008 07:48 PM
mexican blocks jsam Engine Talk 7 11-19-2007 08:08 AM
sleeved blocks Jasperstang308 5.0 Mustang 6 10-26-2007 05:39 PM
