Old 02-28-2010   #11 (permalink)
12-28-2017 09:08 AM
Time Spent Online: 4 Days 22 Hours 19 Minutes 16 Seconds
Re: Tires what hooks and what don't ?
If you find a se that hooks up please let me know I have tried Nittos good year good rich same problem next set will be Mickey thompson ET raidials and a set of slicks for the track
Randy Lichty
Old 02-28-2010   #12 (permalink)
08-21-2017 08:51 AM
Time Spent Online: 1 Day 21 Hours 17 Minutes 47 Seconds
I use nitto 555 dr. They hook good on the street and I think they are supposed to last longer than other drag radials.
Old 02-28-2010   #13 (permalink)
Real Name: kevin
945.0GT's Avatar
san antonio tx
08-10-2011 09:02 PM
Time Spent Online: 3 Days 3 Hours 50 Minutes 5 Seconds
945.0GT's album
945.0GT's Garage
same as jib and i have had mine for over a year still plenty of tread
945.0GT is offline Submit to Clesto
Old 02-28-2010   #14 (permalink)
Real Name: Kyle
Screw-Rice's Avatar
Colorado Springs, Co
02-22-2011 07:45 PM
Time Spent Online: 2 Days 19 Hours 28 Minutes 53 Seconds
Screw-Rice's album
They last longer since they aren't as hardcore as say an M/T DR.
Screw-Rice is offline Submit to Clesto
Old 02-28-2010   #15 (permalink)
Tyre Fryer
Real Name: Donny
dvofordman's Avatar
Boise, Idaho
07-01-2013 06:39 PM
Time Spent Online: 5 Days 9 Hours 36 Minutes 23 Seconds
dvofordman's album
I did have the 555R's in a 255/30R20 and had the exact same problem thru third gear. Switched to the 305 Nitto Drag Radials and they hook really well at the track and will also hook on the street once they warm up. I dont like having two different types of tires for street and for track - mainly cuz I end up getting to the track about once a year. But I still want to be able to hook on the street. I say go as wide as you can with the Nitto DR's.
dvofordman is offline Submit to Clesto
Old 02-28-2010   #16 (permalink)
Yep that's my situation . I don't get to the track either , and don't want a set of tires just sitting in the shop . So i'll probably get a good drag radial in a 315 or whatever i can find to fit my 10.5 wheels .
Old 02-28-2010   #17 (permalink)
Real Name: Devin
Demontang's Avatar
Selah Wa
02-08-2018 03:35 PM
Time Spent Online: 2 Days 8 Hours 3 Minutes 41 Seconds
Demontang's album
I had a set of 275 nittos 555r and they hooked pretty good on the street. The new nitto nt05r sound like they are a lot better.
Demontang is offline Submit to Clesto
Old 03-01-2010   #18 (permalink)
This Bullitt is BAD!!
Real Name: Mark
BaddBullitt's Avatar
Milton , Ontario , Canada
Friends: (13)
01-07-2013 03:30 PM
Time Spent Online: 1 Day 10 Hours 59 Minutes 6 Seconds
Mickey Thompson ET street's will hook like mad.. Just don't get caught in the rain with them.. Other than those i'de go Nitto... Crapitomo's are just that, goodyears suck, and bfg's are alright as long as you go g-force...
Kenne Bell 2.1 439RWHP & 432 Torque.
April 2010 ROTM Winner!!!
http://www.youtube.com/watch?v=AHjmGwZTbBE
http://www.youtube.com/watch?v=w8qVx1t7v4g
BaddBullitt is offline Submit to Clesto
Old 03-01-2010   #19 (permalink)
12-29-2012 07:33 PM
Time Spent Online: 2 Days 16 Hours 33 Minutes 54 Seconds
SHUTUDWN's album
Originally Posted by poneyexpress View Post
Well since i put the supercharger on , i need to get some tire that will hook . I bought a set of 10.5 wheels with the Sumtomo 315/35/17 tires on them . I tought they would help with the traction issues , NOT ! I even air them down to 20psi and still blow them off thru 3rd gear . So what are you guys running with boost ? and what hooks up ? i've been looking at the NITTO 555R's .
Do you need these for street racing or for those random times when you stop in the middle of the road and try a street launch? Even with drag radials you won't hook unless you plan on doing a burnout ever time you want to start from a dig. If that is the case buy some Nitto's or BFGoodrich dr's.
For your safety, I wouldn't air street tires down to 20psi either. And doing a burnout will not help unless you have a tire with a sticky compound, like slicks or drag radials.
For evey day driving I would get a street tire that has a better reputation and quality than Sumitomo. Any max performance summer tire from Goodyear, Nitto, BFGoodrich, Toyo, etc. will do. For safety in the rain you are better off with a real steet tire. Ask anyone that has driven on drag radials in a real down poor and they will let you know how scary it is.
My car makes 400rwtq and with 295 Goodyear eagle F1 GSD3's I don't come anywhere close to spinning through 3rd. Then again, because of the irs's crappy rubber bushings I prefer to hit it from a second gear roll and avoid the nasty wheep hop.
SHUTUDWN is offline Submit to Clesto
don't, hooks, tires
LinkBack to this Thread: http://www.insanemustangs.com/forums/bs-room/17086-tires-what-hooks-what-dont.html
Tires what hooks and what don't ? - BS Room This thread Refback 03-11-2010 08:39 PM 1
Tires thor455400 BS Room 3 08-05-2011 05:51 PM
Got some new tires! already7 Motorcycle and ATV's 4 08-04-2009 09:59 PM
the new kit and new tires are done TH35TH 4.6 Mustang 7 03-08-2009 09:06 PM
tires? mustangfury86 5.0 Mustang 11 01-16-2008 02:39 AM
NEW Tires 1badlxconv BS Room 0 10-13-2007 02:41 PM
