Old 02-28-2010   #11 (permalink)
2v hater
Real Name: jonathan
jsam's Avatar
frankiln ky
11-17-2013 06:04 PM
Time Spent Online: 3 Days 4 Hours 47 Minutes 53 Seconds
jsam's album
jsam's Garage
Re: Will the 5.0 decimate the 4.6?
Originally Posted by poneyexpress View Post
Yes it does . From what i have read the 5.0 will have forged rods and crank , but it's got powdered metal pistons . I could be wrong about this , but if i'm not . How much more power can you get from it with these pistons in it ? but it does sound promising .
forged crank yes. junk powder metal rods as normal. and with a factory 11 to 1 comp ratio there aint gonna be no boosting these without a bottom end rebuild. now they would love some spray with that compression
68 coupe, 93 calypso hatch
www.bowlinggreenmustangs.com
Old 02-28-2010   #12 (permalink)
Yep and the article i read said the the crank case was cramped now with the stock rods . I'm sure somebody will make a set of rods to fit in it .
Old 02-28-2010   #13 (permalink)
05-19-2011 10:52 AM
Time Spent Online: 12 Hours 30 Minutes 10 Seconds
So you're saying that it's gonna be hard to throw a supercharger on these things without changing out the crank and rods?
vonblinden22 is offline Submit to Clesto
Old 02-28-2010   #14 (permalink)
Yep i'm sure if they are the same material used in the 4.6 rods and pistons , it will be about at the limit now .
Old 02-28-2010   #15 (permalink)
Real Name: Joey
92NOTCH's Avatar
Montpelier
12-04-2016 12:48 PM
Time Spent Online: 1 Day 22 Hours 23 Minutes 9 Seconds
92NOTCH's album
92NOTCH's Garage
All i can say is every motor out there will eventually be dominated by another. Just look at the original 5.0L best motor for years then along comes the 4.6L changes the name of the game and just like the old 5.0L still much wanted by lots the 4.6L will hold its on and still be a power house.
Joey 92Notch
92NOTCH is offline Submit to Clesto
Old 03-01-2010   #16 (permalink)
The Man
Real Name: Jeremiah
Wisconsin
03-06-2016 01:22 PM
Time Spent Online: 2 Days 2 Hours 18 Minutes 31 Seconds
JJohnson's album
Originally Posted by johnisbubba View Post
A 4v 5.0 will dominate the 3v 4.6 hands down. Dont be sad if ya have a 4.6 by any means. Im glad ford is adding some much needed displacement. Just remember boost makes everyone equal. Happy hunting.
I don't think it makes us equal, but it does make the spanking my little mill will lay down a little easier to live with.....
Fallen Heroes Racing
Racing to remember and support those who gave all for freedom
Support our sponsors,
Sweet sofas, www.sweetsofas.com
Don West Racing Heads, www.westracingheads.com
Aut-orod controls, www.autorod.net
Afco Radiators, www.www.afabcorp.com
The Fab Shop Custom Headers, www.fabshopheaders.com
Vicotory 1 Performance Valves, www.titaniumvalve.com
JJohnson is offline Submit to Clesto
Old 03-01-2010   #17 (permalink)
2v hater
Real Name: jonathan
jsam's Avatar
frankiln ky
11-17-2013 06:04 PM
jsam's album
jsam's Garage
you can boost 11 to 1 compression but it will have to be VERY low psi. the crank is good to go but the rods are junk and the pistons are also. you need to put dish pistons in to lower the compretion ratio to use moderate to high boost (6 psi and above)
now like i said before nitrous loves high compression but then again you still will have junk rods and pistons
4.6?, decimate
LinkBack to this Thread: http://www.insanemustangs.com/forums/bs-room/17071-will-5-0-decimate-4-6-a.html
Will the 5.0 decimate the 4.6? - BS Room This thread Refback 03-11-2010 07:52 PM 1
