Old 10-23-2009   #1 (permalink)
12-28-2017 09:08 AM
Time Spent Online: 4 Days 22 Hours 19 Minutes 16 Seconds
Porting SVO Heads Need some info
Can someone give me the low down on how to properly port a set of aluminum SVO heads for a 351 Windsor that is about to be a 393 windsor need to do the heads right Just dont have much cash but i do have time and a compressor and tools to use
Randy Lichty
Old 10-23-2009   #2 (permalink)
2v hater
Real Name: jonathan
jsam's Avatar
frankiln ky
11-17-2013 06:04 PM
Time Spent Online: 3 Days 4 Hours 47 Minutes 53 Seconds
jsam's album
jsam's Garage
Re: Porting SVO Heads Need some info
i still say your wasting your time with those heads. you can open the ports up yes but the valves are still to small for a big cube windsor. you are going to choke the shit out of it
68 coupe, 93 calypso hatch
www.bowlinggreenmustangs.com
Old 10-23-2009   #3 (permalink)
12-28-2017 09:08 AM
If thats so what do you recomend I sure cant afford trick flow heads for a mear 3000.00
Old 10-23-2009   #4 (permalink)
Real Name: Jim
J&SPolishing's Avatar
12-20-2016 02:47 PM
Time Spent Online: 3 Days 7 Hours 22 Minutes 29 Seconds
I agree, I wouldn't run anything smaller then a 205cc intake port. Let that big motor breath.
J&SPolishing is offline Submit to Clesto
Old 10-24-2009   #5 (permalink)
2v hater
Real Name: jonathan
jsam's Avatar
frankiln ky
11-17-2013 06:04 PM
jsam's album
jsam's Garage
trick flow, afr 205's, victor jrs will all get the job done. your heads will work yes but you will not make good power with them being they are going to choke the air in and exhaust out.
if what you have is all you can afford right now run with them save up and buy a big set of heads down the road.
i have a set of twisted wedge's on my 395 that was stage 2 ported by tea and milled down to a 54cc chamber. it's all about what you can afford. if you do plan you twisted wedges later on make shure you get pistons with dual valve reliefs
Old 10-27-2009   #6 (permalink)
The Man
Real Name: Jeremiah
Wisconsin
03-06-2016 01:22 PM
Time Spent Online: 2 Days 2 Hours 18 Minutes 31 Seconds
JJohnson's album
What SVO heads are they? I take if from the responses they are not a set of yates like I run.
JJohnson is offline Submit to Clesto
heads, info, porting
porting heads and intake 91stang308 5.0 Mustang 3 07-19-2009 03:47 PM
ModularSpeed CNC Porting Now available!! ModularSpeed ModularSpeed Specials 1 06-08-2009 10:24 PM
5.0 Intake Porting Article johnisbubba Articles/Archives 0 02-15-2008 05:49 AM
SVO 4.6L SOHC Cylinder Head Porting Article johnisbubba Articles/Archives 0 01-12-2008 10:14 PM
need some info, tankstang 5.0 Mustang 16 05-01-2007 02:48 PM
