Old 10-19-2009   #1 (permalink)
12-28-2017 10:08 AM
Time Spent Online: 4 Days 22 Hours 19 Minutes 16 Seconds
SVO Heads
I need some information on some SVO heads I have they are aluminum and I am planning on installing them on a 393 stroker motor But I am not haveing much luck with information on them they have a part # of M6049X302 I would love to Know if they are 58 cc 64cc if they are good heads average heads what they are worth ect All I can find is they were probably off a cobra car they are in good condition but if I wanted to port would it be worth doing or better off left alone what would be a good intake and cam to run with these ???
Randy Lichty
Old 10-19-2009   #2 (permalink)
08-21-2012 07:51 AM
Time Spent Online: 2 Days 2 Hours 52 Minutes 35 Seconds
Re: SVO Heads
Those are GT-40X heads w/64cc combustion chambers
http://www.1fordracing.com/parts/par...tKeyField=2600
-------- added 0 Minutes and 29 Seconds later --------
TECH NOTES
M-6049-X302* Bare Head (64cc Chamber)
M-6049-X303* Complete Head (64cc Chamber)
M-6049-X304* Bare Head (58cc Chamber)
M-6049-X305* Complete Head (58cc Chamber)
THE FAST, EASY WAY TO BOLT-ON 65 HORSEPOWER! TRUE BOLT-ON PERFORMANCE
For use on 289/302/351 Windsor-style engines
Improved air flow over original GT-40 aluminum heads
Intake flows approximately 240 cfm at .550" lift (at 28" of H20)
Exhaust flows approximately 170 cfm at .500" lift (at 28" of H20)
Machined for 1.94" Intake and 1.54" exhaust valve diameters
Unlike some aftermarket heads our GT-40 heads use either GT-40 or aftermarket performance: intake manifolds, headers, and valve covers.
Intake port volume 178cc, exhaust port volume 62cc
High temperature exhaust valve seats. Thick deck for improved sealing, increased section thickness in critical areas for porting, and webbed rocker bosses for improved strength. Designed for bolt-on rocker arms, machined for tapered seat spark plug or gasketed. Compatible with Ford Racing intakes, headers, and valve train components. Can be machined for diagonal exhaust header flange mounting.
High quality original equipment style 356-T6 aluminum castings, machining and components
Each aluminum head weighs approximately 22 lbs. – approximately 25 lbs. lighter than each cast iron GT-40 head.
These GT-40 style heads use AGSF-32C spark plugs
Each GT-40X head is leak tested prior to assembly
Head assembly consists of bare head M-6049-X302/X304 and GT-40 valve train kit M-6090-X302 featuring stainless steel valves. The valve springs are compatible with all Ford Racing roller camshafts. See page 99 for complete list of valve train components.
INSTALLATION NOTES:
Will not fit 1986 5.0L with flat-top pistons unless pistons are notched for valve relief
Must use head bolt kit M-6065-D289 to install cylinder heads on 289/302 blocks or head bolt and head gasket kit M-6051-A50 and intake gasket M-9439-A50/A51
Check rocker arm clearance to valve springs with production rocker arms
Check your intake manifold for port match, not all intakes are compatible due to the tall high-flow ports
Must use M-9439-A50 intake gasket
Old 10-19-2009   #3 (permalink)
03-07-2018 05:23 PM
Time Spent Online: 1 Week 2 Days 8 Hours 53 Minutes 46 Seconds
Re: SVO Heads
here is a head flow chart for them, (and some others) they are way better then stock but as far as aftermarket heads go AFR, TFS, etc are better.
I would like to pick up a set of the 64cc. they are good heads just depends on what your trying to do with them. Not gonna "light the world on fire" with them or set new world records but a good head none the less
NEVER do business with Sam Rivera AKA Sam Wilson of Rivera Race Chassis. Paid 2800 to put car together. NO work was done, never gave back my turbo kit. Now I see old adds of my parts being sold on craigslist while car was at his shop.
Old 10-19-2009   #4 (permalink)
2v hater
Real Name: jonathan
jsam's Avatar
frankiln ky
11-17-2013 07:04 PM
Time Spent Online: 3 Days 4 Hours 47 Minutes 53 Seconds
jsam's album
jsam's Garage
Re: SVO Heads
thoose are to small for a 393. they will choke the shit out of it
68 coupe, 93 calypso hatch
www.bowlinggreenmustangs.com
Old 10-19-2009   #5 (permalink)
03-07-2018 05:23 PM
Re: SVO Heads
x2 I missed the 393w part... Im a dumbass lol!!!
thats a lot of CI for a small head
heads
Need 4.6 heads... CmdrDon BS Room 0 08-28-2009 01:35 PM
351 heads on a 302 91stang308 5.0 Mustang 27 07-05-2009 09:26 PM
some heads mellowout 5.0 Mustang 4 12-10-2008 11:20 PM
302 OEM heads SpdBoss Engine Talk 22 09-24-2007 05:24 PM
4.6 2v heads sigel 4.6 Mustang 3 09-03-2007 10:01 PM
