Go Back   Mustangs Insanity > Mustang Tech Department > 2005 - 2008 Ford Mustang Repair Info > Chassis Electrical > Air Bag (Supplemental Restraint System)
Arming Airbag
Arming Airbag
Arming Airbag
1) Make sure all restraint system diagnostic tool(s) that may have been installed during the repair have been removed from the vehicle and all SRS components are connected.
2) Turn the ignition switch ON.
3) Install RCM fuse F2.17 (10A) and close the cover.
WARNING
Be sure that nobody is in the vehicle and that there is nothing blocking or set in front of any air bag module when the battery ground cable is connected.
4) Connect the negative battery cable.
5) Verify that the system is operational by performing the following:
6) Turn the ignition key from ON to OFF. Wait 10 seconds, then turn the key back to ON and visually monitor the air bag indicator with the air bag modules installed. The air bag indicator should light continuously for approximately 6 seconds and then turn off. If an air bag supplemental restraint system (SRS) fault is present, the air bag indicator will:
A) fail to light
B) remain lit continuously
C) flash
NOTE: The flashing may not occur until approximately 30 seconds after the ignition switch has been turned from the OFF to the ON position. This is the time required for the restraints control module to complete the testing of the SRS. If the air bag indicator is inoperative and a SRS fault exists, a chime will sound in a pattern of 5 sets of 5 beeps. If this occurs, the air bag indicator and any SRS fault discovered must be diagnosed and repaired.
7) Clear all DTCs from the restraints control module using a scan tool.
airbag, arming
Disarming Airbag hotwheels Air Bag (Supplemental Restraint System) 0 08-30-2009 04:58 PM
SRS Protective airbag problem rdwright66 5.0 Mustang 0 08-03-2008 09:41 PM
Airbag treman03 Electronics Talk 2 05-09-2008 04:21 PM
Airbag deploys pumpkin Loadclr Other Video's 4 11-07-2007 12:08 PM
Airbag Light On blackride 5.0 Mustang 4 04-07-2007 04:33 PM
Copyright ©2000 - 2023
