Old 03-01-2008   #1 (permalink)
88 clone's Avatar
nh
11-25-2010 07:39 PM
Time Spent Online: 7 Minutes 47 Seconds
88 clone's album
stange vibration?
when im just normaly cruising the car seems fine but if i drop a gear and hammer it i get this wicked viration on the shifter was thinjking maybe the drive shaft? any help would be awsome
88 cobra clone: bangdesk:
88 clone is offline Submit to Clesto
Old 03-01-2008   #2 (permalink)
9 Hours Ago 04:59 PM
ya could be a driveshaft..does it make a clunk, could be your u-joints...good place to start anyway
Old 03-01-2008   #3 (permalink)
88 clone's Avatar
nh
11-25-2010 07:39 PM
88 clone's album
no clunk just a wicked vibration i just put a new tranny in it its a tko but my t-5 did the same thing and its only when you drop a gear and hit it
Old 03-01-2008   #4 (permalink)
treman03's Avatar
Cleveland, GA
Friends: (10)
05-04-2011 03:06 PM
Time Spent Online: 10 Hours 41 Minutes 49 Seconds
treman03's album
Send a message via Yahoo to treman03
vibration just at a certain rpm?
*SOLD* And I do miss the car.
2000 GT, JBA headers, JBA H-Pipe, Flowmaster mufflers, JLT CAI, Steeda Timing Adjuster, Ported & Polished TB and Plenum, Underdrive Pullies, Eibach Pro kit lowering springs, MM CC Plates
treman03 is offline Submit to Clesto
Old 03-01-2008   #5 (permalink)
Allen Weatherford
2 Days Ago 09:27 PM
Time Spent Online: 2 Weeks 1 Day 19 Hours 11 Minutes 59 Seconds
Mine has a vibration to it too! But it only starts at about 85 MPH and stays steady from there on up. It doesn't matter what gear it's in, BUT it will do it more when I drop to 4th and stand on it!
I am going to get one of those Ford Racing Aluminum Driveshafts for mine.
I think that they are only like $250 for a complete shaft with joints.
Old 03-01-2008   #6 (permalink)
09-18-2011 11:13 PM
Time Spent Online: 1 Day 4 Hours 18 Minutes 40 Seconds
Hows your trans mount?
Old 03-01-2008   #7 (permalink)
Minot North Dakota
01-03-2012 10:26 PM
Time Spent Online: 1 Week 5 Days 9 Hours 41 Minutes 28 Seconds
I agree with both suggestions above. Check your driveshaft and your trans mount. If you can shake the DS and feel it wiggle, one of the U-joints is out. Make sure it's the u-joint and not a bad pinion bearing in the rear axle housing. $20 for a new U-joint and you're in there. I'd say rear joint since you had to work with the front to get the new yoke on. If that's fine, your tranny mount may be sloppy and allow the tranny to move too much. $45 later and you have a new poly one. If both of those are fine, I'd head to the harmonic dampner and then to the wheel balancing.
Good luck
93GT = 5.0 & SF feature Nov 05 p60. She's gone but not forgotten......
99 F250 PSD much modded daily driver. Gone too.
63 Galaxie = 4.6 DOHC/4R70W swap. Sitting waiting.
2003 F350 DRW CCLB Lariat 6.0. Current ride for the toy hauler.
Old 03-02-2008   #8 (permalink)
yeah i've also heard that theres a rubber seal type thing in the harmonic balancer that will wear out and cause it to vibrate like hell. i agree with dave tho, check the u-joints and trans mount first, they would be a lot easier to fix.
Old 03-02-2008   #9 (permalink)
I would check your dampner first............
Old 03-02-2008   #10 (permalink)
03-29-2011 07:09 PM
sound like a u-joint. they get tight when the get old a lose their lubrication which causes the vibration especially on acceleration. do u notice the same vibration when accelerating hard from a stop?
Vibration in clutch pedal.... crossland5 4.6 Mustang 9 04-21-2010 07:20 AM
Pinion Seal and wierd vibration! HooniganRacing Suspension/Drivetrain Talk 4 03-07-2010 09:18 PM
vibration... Intmdtr 4.6 Mustang 26 10-26-2007 09:13 AM
Vibration in car??????? skipnutz 5.0 Mustang 14 06-20-2007 10:12 AM
Vibration Problem E_VilleStang23 4.6 Mustang 1 05-31-2007 05:14 AM
