Old 11-01-2007   #1 (permalink)
1badlxconv's Avatar
Englewood CO
02-06-2010 08:53 PM
Time Spent Online: 2 Days 2 Hours 59 Minutes 40 Seconds
1badlxconv's album
Send a message via MSN to 1badlxconv Send a message via Skype™ to 1badlxconv
Question front end support
i have a question. what does the font bumper cover held by and where to find the bolts? im almost done finding all the pats for my car, i just need the bracketry and bolts that holds all the fenders and bumpers together? and by the way, its a 91 lx, if that would help(i know it does)
1badlxconv is offline Submit to Clesto
Old 11-01-2007   #2 (permalink)
NoMo5o's Avatar
Colorado Springs CO
05-09-2011 11:45 PM
NoMo5o's album
THere are two L shaped brackets that come off the front of the top portion of the radiator support in between the head lights. there are two straight brackets that come off the side of the radiator support and go to the front of the fender. Then you have bolts along the inside of the front of the fender that hold the fender and the front bumper cover together.(HINT: having a second person to make sure the fender and the bumper cover are lined up perfectly helps alot and will make the car look right). You have a bolt right infront of the door under the fender that you have to get to from the door jamb with the door open(just below the mirror). There is a bolt on the under side of the car just in front of the door and three on the top pf the fender under the hood. Also the bolts that hold the air deflector on the underside of the bumper hold the bumper cover to the radiator support. I don't know what to tell you about what size they are. I have always been able to reuse the ones that come off the car. I also snag up every nut and bolt that I remove or that is laying in or around any mustangs at the junk yard.]
here is a picture of the straight bracket that comes off the fender to the side of the radiator support.
http://www.latemodelrestoration.com/...0%201&comp=LRS
here is a bolt kit for the fenders. You will need 2 kits.
1989 GT[SIGPIC]
Old 11-01-2007   #3 (permalink)
1badlxconv's Avatar
Englewood CO
02-06-2010 08:53 PM
1badlxconv's album
do you know if there is anything else?
Old 11-01-2007   #4 (permalink)
NoMo5o's Avatar
Colorado Springs CO
05-09-2011 11:45 PM
NoMo5o's album
Headlight panels is riveted to the bumper cover. You may have to drill out and re-rivet. , But you can just disconnect the wiring to the bulbs and you can remove and install the headlilghts with the bumper off the car a little easier. The antenna in the passenger side fender could be a problem. You may have to cut and resplice that. I have never actually tried to get the fender off and keep the wire intact. Oh and inner fender wells have to be removed pretty much before you can do anything else. They will be the biggest pain in the ass aside from lining everything up when you get it put back together.
p.s. When you are removing the old front end you can leave the bumper and fenders attached to each otherto save some time. just don't forget to remove the bolts from the straight bracket that is attached to the side of the radiator support first.
Old 11-01-2007   #5 (permalink)
08-21-2012 06:51 AM
Time Spent Online: 2 Days 2 Hours 52 Minutes 35 Seconds
Cool. Im glad you posted this. I was going to myself shortly. I have to replace my front bumper cover. I assume its the same on a GT.
Old 11-01-2007   #6 (permalink)
NoMo5o's Avatar
Colorado Springs CO
05-09-2011 11:45 PM
NoMo5o's album
Other than the fog light b.s. yes.
Main support mustangfury86 5.0 Mustang 15 09-16-2010 11:29 PM
Support Our Troops No1FordGirl BS Room 11 12-06-2009 01:34 PM
New 2009 calander with corporate support. einehund Misc. Pic's 9 01-01-2009 08:15 PM
Thnx for your support and Votes!! BLWN93 5.0 Mustang 2 11-01-2007 09:58 PM
Procharger support jcomolli 4.6 Mustang 12 07-19-2007 07:51 AM
