Old 03-23-2007   #1 (permalink)
03-02-2008 05:24 PM
car won't stabilize on smog dyno HELP!
Hey everyone, I'm having trouble keeping my car stabilized at 15 mphs on the smog dyno. It's an 85 carburrated that I recently tuned up. The car slighty jerks up and down and won't stay at 15mph. I'm not sure what else I can do. The carb was rebuilt not too long ago. Could it be a vacum problem? I made sure that all the vacum lines are connected. Any suggestions?
Ravishing11 is offline Submit to Clesto
Old 03-23-2007   #2 (permalink)
04-28-2018 09:44 AM
Time Spent Online: 4 Weeks 11 Hours 40 Minutes 24 Seconds
Not knowing alot of the history of what has been done to the engine, i would first look at all of your vacuum line's and make sure there are no cracks in them where they connect to there fittings.......then i would look at the electrical parts, spark plug wires, are they new? If not, try new one's. If they are, are they touching anything metal, or each other? If they are cheap wire's and they are touching each other, they could be connecting together during spark......then move to the cap and rotor, are those new? if so, pop the cap and ensure that there are no white lines in side the cap, white looking line's usually indicate a small crack, and look at the end of the rotor, if it look's like it has a carbon build on it, change the cap and rotor.....
That's about it at first glance.
Old 03-23-2007   #3 (permalink)
03-02-2008 05:24 PM
Yea, I put brand new plugs, cap, and rotor. The wires are accels (not new, but still good) and they aren't touching each other. However, when I put the heat risers back on the air cleaner I had to wedge the tubes between the bbk headers because I no longer have heat stoves on the headers. By doing that, the heat riser tube is now wedged against the boot of the wire. Could that be affecting the spark and causing my problem?
Old 03-23-2007   #4 (permalink)
04-28-2018 09:44 AM
It very well could be..........
Old 03-23-2007   #5 (permalink)
03-02-2008 05:24 PM
Thanks for the help hotwheels. I appreciate it.
Old 03-23-2007   #6 (permalink)
04-28-2018 09:44 AM
no problem, let us know if that worked or if you find or don't find the problem.
Smog, A/C, P/S delete question trey 5.0 Mustang 4 01-30-2012 10:02 PM
smog and a/c delete? fr50089 Engine Talk 1 05-01-2011 06:28 AM
Must be the Smog! already7 BS Room 0 08-18-2009 02:04 AM
x-pipe = no smog thor455400 5.0 Mustang 8 09-29-2007 01:55 PM
smog and ac delete? mustangfury86 5.0 Mustang 5 06-09-2007 11:21 AM
