Old 03-23-2007   #11 (permalink)
Real Name: Justin
mustangfury86's Avatar
shreveport , la
02-26-2012 09:42 PM
Time Spent Online: 1 Day 1 Hour 27 Minutes 47 Seconds
no modifcations yet just got the car about a month to a month and a half ago .
and for the head gasket it could be but as you say you felt moisture from youre exhaust it couldalso just be condensation.
as to were i am from I am from shreveport ,LA
Old 03-23-2007   #12 (permalink)
Has the Mustang Bug...
06-20-2008 12:47 PM
If it looses coolant, there is a leak somewhere because the fluid is escaping. It is impossible for the coolant to just disappear. If you can not find a physical leak from a hose, or simular, you may have a head gasket leak. Are you getting any condensation out the tail pipe?
1 clean notch is offline Submit to Clesto
Old 03-23-2007   #13 (permalink)
Real Name: Justin
shreveport , la
02-26-2012 09:42 PM
i am gitting condensation in the tail pipe but not anymore than normal in La I was thinking it could be the fan clutch isnt working well and when it dosent work at all the car over heats causing the coolant to turn to steam and expand and then go out throught my over flow then when it cools the coolant is low but that is just a theory i have.because it dosent always over heat.
Old 03-23-2007   #14 (permalink)
Real Name: Justin
shreveport , la
02-26-2012 09:42 PM
is any one using a flex fan and gitting rid of the clutch
Old 03-23-2007   #15 (permalink)
02-18-2012 06:50 AM
Time Spent Online: 5 Days 1 Hour 55 Minutes 7 Seconds
i've always run an electric fan and had no problems with mine.
Old 03-23-2007   #16 (permalink)
carbureted idiot
♥ wendy ♥'s Avatar
Port Richey, FL
06-30-2009 11:24 PM
Time Spent Online: 4 Hours 28 Minutes 47 Seconds
Send a message via AIM to ♥ wendy ♥ Send a message via Yahoo to ♥ wendy ♥
i had to turn to an electric fan as well, but only after i started modding the motor and messing with the pulley sizes.
| 1968 mustang fastback | 1991 mustang lx coupe |
♥ wendy ♥ is offline Submit to Clesto
Old 03-23-2007   #18 (permalink)
Real Name: Devin
Demontang's Avatar
Selah Wa
02-08-2018 03:35 PM
Time Spent Online: 2 Days 8 Hours 3 Minutes 41 Seconds
Demontang's album
I had this problem with my 90. It would get hot and then cool down, It never got over heated because I would pull over and let cool before it did. I replace every thing and nothing help tell I replaced the fan with an electric one.
Demontang is offline Submit to Clesto
Old 03-23-2007   #19 (permalink)
Real Name: Justin
shreveport , la
02-26-2012 09:42 PM
i havent actual let it over heat i alway shut it off before it gets 2 hot
Old 03-23-2007   #20 (permalink)
j-rich65
colorado springs
08-13-2008 04:30 PM
j-rich65's album
could be a bad fan, try a block tester to check for hydro carbons in the coolant, not always with a bad head gasket does coolant get in the oil, because cylinder pressure is far greater than cooling system pressure, i would think that an intake leak would leak coolant into the lifter valley
j-rich65 is offline Submit to Clesto
Overheating issues tpcobra95 4.6 Mustang 8 05-20-2010 04:57 PM
Overheating, Need Help Yellow94GT 5.0 Mustang 17 09-12-2007 04:04 PM
overheating Joeybutta BS Room 27 08-31-2006 01:31 PM
