Old 07-12-2009   #1 (permalink)
BB90GT's Avatar
10-16-2014 12:51 AM
Time Spent Online: 4 Days 10 Hours 26 Minutes 49 Seconds
BB90GT's album
BB90GT's Garage
Question Ignition ?
So driving the car home tonight and I turn a corner get the car rolling and go to shift as I let the clutch and give it a little gas the car just dies. Well now it wont fire back up. I already checked to make sure I have fuel and I do. Next I checked to see if the MSD 6AL is working and I dont think it is. I pulled the coil plug off the distributor cap and stuck a spark plug in it and ground it to lug that comes straight from the battery and cranked the motor over and got absolutely no spark. Just checking to see if A if I am checking for spark in a manner that will give me accurate results and B anyone else have this f*()ing problem with the MSD stuff they run?
Thanks for any and all help.
Bruce
p.s. the car runs great with the cam and clutch and trans and all the other stuff I had to change.
Do you think I can run a digital 6 instead of the 6al and would it be better than what I am running now.
LSU TIGERS
BB90GT is offline Submit to Clesto
Old 07-13-2009   #2 (permalink)
04-28-2018 10:44 AM
Time Spent Online: 4 Weeks 11 Hours 40 Minutes 24 Seconds
Re: Ignition ?
bruce, when you turn over the engine with the cap off, does the rotor still turn?
Old 07-13-2009   #3 (permalink)
02-17-2014 05:31 PM
Re: Ignition ?
What coil are you running? If you are still with the stock coil, could it be that it can't handle the new set up?
Old 07-13-2009   #4 (permalink)
BB90GT's Avatar
10-16-2014 12:51 AM
BB90GT's album
BB90GT's Garage
Re: Ignition ?
Well Doug at first I though surely that it did but, after checking tonight it does not turn when cranking hte motor. So I ask what hte hell is the fix for this and dont tell me it broke a cam gear or something please casue if it did I might put the car up for sale. THanks and I patiently await you response
BRuce
Old 07-14-2009   #5 (permalink)
Novi_5.0's Avatar
08-31-2011 11:35 AM
Time Spent Online: 1 Day 9 Hours 31 Minutes 7 Seconds
Novi_5.0's album
Smile Re: Ignition ?
If you broke a cam gear... you probably broke the set pin. If so... you got lucky!
Worse... you broke the oil pump drive. If caught in time... you can simply change out an oil pump and drive... but even worse... you lost oil pressure too and lost bearings.
It would be tough to diagnose without being there... pull the distributor carefully and maybe the gear will remain attached. Otherwise... a long magnet reach tool...
Valves moving up and down? If not... Timing chain went.
Novi_5.0 is offline Submit to Clesto
ignition
Ignition problems.... earlsflyincobra Electronics Talk 9 03-24-2010 06:02 PM
Ignition? 86saleen#126 BS Room 4 12-23-2009 11:17 AM
MSD Ignition 86saleen#126 BS Room 4 11-30-2009 06:49 PM
Broke my key off in the ignition hotwheels BS Room 15 11-20-2009 01:02 PM
ignition help anybody?? hambone420 4 Cylinder NA and Turbo 2 04-23-2008 12:44 PM
