Old 07-06-2009   #1 (permalink)
fr50089's Avatar
carthage,mo
06-21-2011 07:54 PM
Time Spent Online: 1 Day 4 Hours 12 Minutes 35 Seconds
fr50089's album
fr50089's Garage
fuel injection to carb
i just recently got a 302 fuel injected motor that i am going to tear down and rebuild. my question is is there anything that i need to do in particular to make it carbed or will it all be the same? does anyone want to trade for the stock injection stuff for a good intake and carb?
fr50089 is offline Submit to Clesto
Old 07-06-2009   #2 (permalink)
Novi_5.0's Avatar
08-31-2011 10:35 AM
Time Spent Online: 1 Day 9 Hours 31 Minutes 7 Seconds
Novi_5.0's album
Smile Re: fuel injection to carb
You will need to reduce the fuel pressure... and have that fuel returned to the tank after it has been reduced. Several companies offer Fuel pressure regulators or Fuel Logs to make this happen. I used a Moroso fuel log and after Aeromotive fuel pressure regulator.
You will need an aftermarket distributor (You need that hardened gear for the distributor too if running the roller cam), and a box to fire it off... duraspark or MSD will work fine... you will need an ignition coil.
If you want to make it easier to tune... get the MSD setup that allows you to adjust timing advance inside the car. So if you decide to add a bottle to it... you can take out a few degrees of timing. Or... if you add race fuel you can add timing.
Novi_5.0 is offline Submit to Clesto
Old 07-07-2009   #3 (permalink)
fr50089's Avatar
carthage,mo
06-21-2011 07:54 PM
fr50089's album
fr50089's Garage
well heres the deal im putting this motor in a 53 chevy that my dad gave me so im not too concerned with making it a badass motor with alot of aftermarket stuff done to it. i just want to make it nice enough to take to local cruise nights and things like that for right now. so i just need to do the main things to it to make it run and reliable. thanks for the info
Old 07-07-2009   #4 (permalink)
Novi_5.0's Avatar
08-31-2011 10:35 AM
Novi_5.0's album
With an early ride... you'll also have to create a means to return that fuel to the fuel tank.
You won't be able to deviate from the suggestions I provided... No short cuts on this one... other than a low volume electric Blue pump, and then you can delete the fuel log requirement.
Old 07-07-2009   #5 (permalink)
2v hater
Real Name: jonathan
jsam's Avatar
frankiln ky
11-17-2013 06:04 PM
Time Spent Online: 3 Days 4 Hours 47 Minutes 53 Seconds
jsam's album
jsam's Garage
put a pick up in the tank from a 85 gt and run a mechanical pump. run a 3/8 fuel line the length of the car and call it a day
68 coupe, 93 calypso hatch
www.bowlinggreenmustangs.com
Old 07-07-2009   #6 (permalink)
Novi_5.0's Avatar
08-31-2011 10:35 AM
Novi_5.0's album
I don't believe he will be able to run a mechanical pump on a late model 5.0 motor...
Someone prove me wrong on this one... I haven't seen it happen "Yet"
Old 07-08-2009   #7 (permalink)
10-03-2015 04:28 AM
Time Spent Online: 2 Days 5 Hours 51 Minutes 22 Seconds
1badf100's album
It is cool that you will put this in a 53 chevy. Do you want to sell the fuel injection setup?
1badf100 is offline Submit to Clesto
Old 07-08-2009   #8 (permalink)
2v hater
Real Name: jonathan
jsam's Avatar
frankiln ky
11-17-2013 06:04 PM
jsam's album
jsam's Garage
yes you can. it's a timing cover a fuel excentric change away. it's no biggie. my 93 is done this way
Old 07-08-2009   #9 (permalink)
Novi_5.0's Avatar
08-31-2011 10:35 AM
Novi_5.0's album
That makes sense... more work! hee hee
carb, fuel, injection
351 Fuel Injection fitz101 BS Room 39 11-20-2008 08:18 PM
Converting carb to fuel injection fitz101 BS Room 1 10-17-2008 08:33 PM
Fuel injection conversion help again... Blüestreak 5.0 Mustang 4 05-20-2007 06:42 PM
Fuel injection conversion... Blüestreak 5.0 Mustang 5 03-27-2007 12:47 PM
EFI guide for aftermarket fuel-injection systems hotwheels 5.0L 0 09-01-2006 12:36 AM
