Go Back   Mustangs Insanity > Mustang Talk > Mustangs > 4 Cylinder NA and Turbo
4 Cylinder NA and Turbo Discussions about stock or modified 4 cylinders, including the performance 2.3L mustangs
Old 05-02-2007   #1 (permalink)
MustangCowboy's Avatar
Colorado
06-24-2011 01:12 AM
Time Spent Online: 1 Day 11 Hours 46 Minutes 40 Seconds
Rearend ?
What rearend to the 4cyl cars have? I Know 5.0's have an 8.8 but was thinking the 4 bangers have like a 7.5. Is this correct? Will the 8.8 go into my 4 banger with out major problems? Does anybody know what gears a 91 4cyl auto would have? The reason I am asking is because I can get an 8.8 with 3.27 posi, and I would love to improve my off the line but I dont know what I have now, and I was wondering how much this would kill my highway.
Get In, Sit Down, Shut Up, And Hang On
MustangCowboy is offline Submit to Clesto
Old 05-02-2007   #2 (permalink)
QWKPONY
fitz101's Avatar
Michigan
4 Weeks Ago 07:22 AM
Time Spent Online: 2 Days 8 Hours 42 Minutes 54 Seconds
fitz101's album
fitz101's Garage
Send a message via AIM to fitz101
you should be good with the 8.8 and the 3.27 gears, gas mileage shouldnt be bad with that gearing. And, I believe you are right with the 7.5 rear end off of the 4 cylinder. I also believe the 8.8 should go in pretty easy, not 100% sure on that though.
1992 Notch Back
2005 Focus ZX4 ST
apple juice $1.39
new shoes $50.00
electricity bill $146.00
Fitz101 deepthroating you in the parking lot of wal-mart ......PRICELESS
Gayer then Einehund
But not as gay as Intmdtr
Which in that case is also gayer then JIB
fitz101 is offline Submit to Clesto
Old 05-02-2007   #3 (permalink)
NoMo5o's Avatar
Colorado Springs CO
05-10-2011 12:45 AM
NoMo5o's album
Four cylinders come with 7.5. They are usually geared lower than 8.8's probably 3.27's or 3.42? So an 8.8 with 3.27's shoudn't effect your gas mileage. If the 8.8 is from a mustang it will bolt right in with no modifications.
1989 GT[SIGPIC]
Old 05-02-2007   #4 (permalink)
It's never done
Asheville, NC
09-09-2009 12:03 PM
Time Spent Online: 17 Minutes 37 Seconds
Send a message via Yahoo to Project$200
Is the e-brake cable not different from the 5.0 cars to the 2.3?
Met Gray 89'LX Notch 2.3L for now
0-60 sometime today!
Sold Calypso Green Met 92 LX Notch 5.0 Stick
Project$200 is offline Submit to Clesto
Old 05-02-2007   #5 (permalink)
rockytoohot's Avatar
Saskatchewan, Canada
09-30-2010 09:00 AM
Time Spent Online: 11 Hours 58 Minutes 18 Seconds
I believe the e-brake cables are the same and the 8.8 will bolt right in with no modifications needed.
rockytoohot is offline Submit to Clesto
Old 05-02-2007   #6 (permalink)
Colorado
06-24-2011 01:12 AM
thanks that is what I was hoping to hear. I need to do a vin check to see what gears I have, since there isn't a little tag on the rearend.
Old 05-03-2007   #7 (permalink)
Colorado
06-24-2011 01:12 AM
I just went and looked at the door tag and I've got 3.73's now, so I deffinitely don't want 3.27's. I am willing to sacafice some top end to get some off the line, so what will going to 4.10 or 4.11, or whichever it is in the 8.8, do to my top end.
Old 05-03-2007   #8 (permalink)
08-19-2009 08:34 PM
Time Spent Online: 15 Hours 26 Minutes 2 Seconds
BLUE92's album
That small of a change in gear ratio will not effect your top end too bad, but on the same note it won't effect your bottom end a whole lot, but it is still a small improvement, so i say go for the 4.10s.
BLUE92 is offline Submit to Clesto
Old 05-03-2007   #9 (permalink)
Tired of Wrenching...
mr deeds's Avatar
Florida
11-23-2008 12:25 AM
Time Spent Online: 4 Minutes 51 Seconds
mr deeds's album
Hey cowboy,
4.10 = 8.8 inch
4.11 = 9 inch
Gear ratios are always subject to debate. With the smaller displacement engines, some say 3.73 w a manual and 4.10 w an auto. It's all subjective, and depends on how you drive and what you are looking to do. With your HP and desire to pull better off the line, I'd go with the 4.10s. I had 4.10s in a V6 and loved them. Which to get depends on how you drive. You'll notice the difference in the pull in the lower gears, but you shouldn't notice a HUGE difference between what you have now. At interstate speeds the 4.10s will rev a little higher than the 3.73, but nothing to be concerned about. More important, whatever rear gears you get, be sure to get a limited slip posi. That will make more of a difference in performance than the difference between 3.73 and 4.10. BTW, if you decide to swap the axle, be aware when shopping that the pre-1999 solid axles are about 1.5 inches shorter than the 99-04 models.
mr deeds is offline Submit to Clesto
Old 05-03-2007   #10 (permalink)
Colorado
06-24-2011 01:12 AM
Thanks that really helps. If anyone has a fox body rear with 4.10 or something higher than 3.73 that they want to get rid of let me know. Every little bit will help and I was planning on swaping the gears when I do the turbo anyway.
rearend chrajohns0 5.0 Mustang 8 01-26-2011 09:44 AM
8.8 Rearend 89 RED DRAGON 5.0 Mustang 11 11-24-2007 08:55 PM
My rearend shrunk Duece Mustang Pics 5 07-07-2007 03:53 AM
Rearend problems BB90GT 5.0 Mustang 10 05-03-2007 05:56 PM
rearend treman03 BS Room 4 01-05-2007 02:48 PM
