Go Back   Mustangs Insanity > Mustang Talk > Mustangs > 4 Cylinder NA and Turbo
4 Cylinder NA and Turbo Discussions about stock or modified 4 cylinders, including the performance 2.3L mustangs
Old 10-11-2006   #1 (permalink)
Too Ancient for JM Status
Daytona Beach
03-31-2010 09:59 AM
Time Spent Online: 37 Minutes 52 Seconds
Twin Turbo Build Question?????
I am building a 66 AC Cobra kit. I have a 5.0, bored 30 over, with forged rods and pistons, E303 cam, Y303 heads, and a mildly ported and polished Cobra upper/lower intake. I have 2 Garrett T4 turbos, 2 Tial 38mm waste gates and a 50mm blow off valve, and a Microtech ECU system. I am looking for somewhere around 450 to 500 hp.
The fellow at Stage 6 suggested I downsize the turbot's, since I am not looking for MEGA hp and also since I have a space problem. So, my question is what Turbo's should I use??
I found a Turbo match up chart on allfordmustangs.com and when I put in the info it says to use T3, Comp. trim 45, and Turbine HSG A/R .49. When searching most T3's I find w/trim 45 show .48???? Much difference??
earlsflyincobra is offline Submit to Clesto
Old 10-11-2006   #2 (permalink)
Moderator
Erich's Avatar
MD
04-05-2010 01:38 PM
Time Spent Online: 10 Minutes 55 Seconds
Erich's album
Erich's Garage
T4s are going to be big. With .60/.63 garretts from pre 87 turbo coupes with manual trans, you will be able to make over 500 hp. The auto version may work too. I run 87-88 turbo coupe IHI units. I make 400 rwhp 500 ft-lb on GT40P headed stock cammed motor with stock intake. The IHIs spool really fast but supposedly top out at like 5-6 grand. They are small too.
Erich
1989 Notch 5.0 homebuilt twin turbo
1997 GT 248a ATI Procharger P600B Intercooled
Erich is offline Submit to Clesto
Old 10-12-2006   #3 (permalink)
Daytona Beach
03-31-2010 09:59 AM
Just realized this probably should have been under the Turbo Talk section rather than here...if there is a moderator reading this, can you move it for me..>Thanks, Earl
Old 10-12-2006   #4 (permalink)
Moderator
Erich's Avatar
MD
04-05-2010 01:38 PM
Erich's album
Erich's Garage
I'm a moderator but somehow I can't move the thread.
Erich
Old 10-12-2006   #5 (permalink)
91saleentwinturbo's Avatar
04-30-2010 05:57 PM
Time Spent Online: 58 Minutes 47 Seconds
t4 turbos willl be fine as long as you maintain a low boost no more than 10-15 lbs of boost.
tire roaster
91saleentwinturbo is offline Submit to Clesto
Old 12-08-2006   #6 (permalink)
Has the Mustang Bug...
06-20-2008 01:47 PM
I agree... T4's are a perfect match for a twin setup on a 302. Do you know what the specs are on the turbo's? T4 is pretty vague... Ask Deuce about his twin 44's on his street car... That thing was sick, and made more than enough power.
1 clean notch is offline Submit to Clesto
Old 12-08-2006   #7 (permalink)
nem·e·sis
$hawn's Avatar
Florida
08-11-2011 09:37 PM
Time Spent Online: 5 Minutes 22 Seconds
$hawn's album
$hawn's Garage
Just be careful your existing motor doesn't have too high of A c/r.
10.48 @ 131
$hawn is offline Submit to Clesto
Old 04-14-2007   #8 (permalink)
Goodbye Lil Red.
89GT2.3H's Avatar
Topeka, Kansas
11-01-2011 12:29 PM
Time Spent Online: 1 Day 15 Hours 55 Minutes 43 Seconds
89GT2.3H's album
Hey you just have 2 4 bangers sharing the same crank shaft.
WHY NOT post here?
89GT2.3H is offline Submit to Clesto
Old 04-14-2007   #9 (permalink)
Real Name: Jim
J&SPolishing's Avatar
9 Hours Ago 10:50 PM
Time Spent Online: 3 Days 7 Hours 1 Minute 56 Seconds
Personally I would not do twin t4's. Cobra replicas are very light cars and don't need alot of power to make go fast. Contact Precision Turbo and have them set you with the proper turbos.
One of the t4's you have will probably put you over your horsepower goal. A low dollar MPt70 will make 500hp all day long on a 5.0 with heads and cam.
J&SPolishing is offline Submit to Clesto
Twin Turbo Viper on Dyno einehund Member's Personal Video's 5 11-17-2009 11:03 PM
Twin turbo build J&SPolishing Turbo Talk 22 10-20-2009 06:49 PM
Twin Turbo New Edge. trueblue02 Other Video's 11 10-14-2008 12:07 AM
twin turbo vid clint Other Video's 1 12-19-2006 02:00 PM
My old Twin Turbo'd Stang Duece Other Video's 5 10-30-2006 07:26 AM
