Old 01-29-2008   #1 (permalink)
03-21-2011 03:53 AM
Time Spent Online: 6 Hours 21 Minutes 26 Seconds
Joe02GTBlu's album
Cool 75mm throttle body
Just installed new Mac 75 mm t/b. Initial start up sends rpms to 2000 for a second or two then idles down. Car now idles several hundred rpms higher. Throttle sticks a little sometimes. Adjusted throttle stop on t/b and it now has smoother engagement. Called Mac and they claim the higher rpm is normal. I tried adjusting the idle screw. I turned it clockwise about one quarter of a turn. That is all i could get it to turn. It did make a slight difference. It still idles high and i am having to ride the brake alot. Mods include C&L elbow, Pro-M cold air intake and steeda underdrive pulleys. Any help would be great. Thanks!
Joe02GTBlu is offline Submit to Clesto
Old 01-29-2008   #2 (permalink)
09-18-2011 11:13 PM
Time Spent Online: 1 Day 4 Hours 18 Minutes 40 Seconds
Clockwise would raise your idle bro, Check to see that the gasket is sealing on the TB
Old 01-29-2008   #3 (permalink)
3 Weeks Ago 10:49 AM
Got a 75 on mine never noticed a differance. Sure sounds good when you open it up .
Old 01-29-2008   #4 (permalink)
Try this: with the engine off, take a feeler gauge (.010-.012) and underneath your throttle body, you will see a little adjustment bolt, back that off till you feel a slight drag between the bolt and the throttle body linkage......with that done, we will check the tps voltage.....turn the key on, engine off, take a needle and stick it into the green wire....use a volt meter and check your voltage......should read .096.....if not, you will need to barely loosin the two phillip screws and find .096.....tight down the bolt's, start the car and see how she feels......
Old 01-30-2008   #5 (permalink)
03-29-2011 07:09 PM
x2, also unhook the iac motor while the car is running then plug it back in, if that doesnt help besure to disconnect the battery for a few minutes before running it again. i had the same problem with my accufab, but between adjusting the tps, resetting the iac and unhooking the battery i got her to idle like stock.
Throttle body vs MAF dseward BS Room 4 05-26-2011 06:43 PM
throttle body spacer 91stang308 4.6 Mustang 4 05-18-2009 10:59 AM
bbk cai and throttle body jsam 5.0 Mustang 4 12-30-2008 07:55 PM
Throttle Body LV_Yankee 4.0L V6 Specific 14 02-18-2008 06:33 AM
throttle body? 91stang308 5.0 Mustang 13 02-08-2008 07:16 PM
