Old 09-07-2007   #1 (permalink)
06-21-2013 03:05 PM
Time Spent Online: 1 Week 2 Days 22 Hours 47 Minutes 45 Seconds
Underdrive pulleys
Am getting a set of underdrive pulleys. anything i should know, like, should i get a more powerful alternator to compensate for the lower spin speed? how easy are they to get off? Do I need a pulley puller or will elbow grease and some cuss words get the job done?
Old 09-07-2007   #2 (permalink)
Nitrous Injected
juiced2002gt's Avatar
Wilkesboro, North Carolina
11-18-2007 08:38 AM
dont change the alternator pulley if you've still go the stock alternator because you'll end up havin to buy a new alternator a few weeks because it spins it slower which causes it not to charge correctly (thats what happened to mine anyway). you'll probly need to get a high performance alternator if you're gonna change the pulley on it. i went to autozone and did their loan a tool thing and borrowed a pulley puller and cuss words and elbow grease are a must.
-2002 Mustang GT
-2000 S-10 Xtreme
-2003 GSXR 600
juiced2002gt is offline Submit to Clesto
Old 09-07-2007   #3 (permalink)
j-rich65
colorado springs
08-13-2008 04:30 PM
j-rich65's album
use a puller it is a press on pulley, it also a good idea to use an installer as well because if you try to tap into place you could damage the crank thrust bearing, the puller you use should match up to the three threaded bolt holes already in the damper, do not use a jaw style puller, you could damage the pulley
j-rich65 is offline Submit to Clesto
Old 09-07-2007   #4 (permalink)
Re Member
Western KS
06-26-2011 06:57 AM
Time Spent Online: 1 Day 10 Hours 43 Minutes 36 Seconds
lostsohcs's album
I recently put on a set of Steeda Pulleys. It took about 2 and a half hours. There were really no problems. Torqueing the crankshaft pulley was the hardest part. If you have an impact wrench I would highly recommend using it. I removed the overflow and fan from the radiator and there was plenty of room for a half inch impact. No charging or cooling problems after a couple thousand miles.
lostsohcs is offline Submit to Clesto
Old 09-07-2007   #5 (permalink)
treman03's Avatar
Cleveland, GA
Friends: (10)
05-04-2011 02:06 PM
Time Spent Online: 10 Hours 41 Minutes 49 Seconds
treman03's album
Send a message via Yahoo to treman03
I've had mine on quite awhile now and I haven't had a problem with anything yet.. Not that bad to put on either, just alittle time.. You will need an impact wrench to replace the alt. pulley if you decide too....
*SOLD* And I do miss the car.
2000 GT, JBA headers, JBA H-Pipe, Flowmaster mufflers, JLT CAI, Steeda Timing Adjuster, Ported & Polished TB and Plenum, Underdrive Pullies, Eibach Pro kit lowering springs, MM CC Plates
treman03 is offline Submit to Clesto
Old 09-07-2007   #6 (permalink)
03-29-2011 06:09 PM
i bought the moto blue pullies from rpm outlet for my 2000 gt. they are really nice parts! made a nice difference in the way the car pulls. seems like it revs more freely now too! you will need an impact to get the alt. pulley off and a puller for the balancer. not a bad job, it only took about 1.5 hours to do in the 95 degree heat a couple weeks ago. make sure to draw a picture of how ur belt goes. my car was missing the sticker!
Old 09-07-2007   #7 (permalink)
06-21-2013 03:05 PM
thanks. i can steal a pully puller from the bradley mechanics at work.
Old 09-12-2007   #8 (permalink)
Samsstang's Avatar
06-12-2013 08:11 PM
Time Spent Online: 57 Minutes 38 Seconds
Samsstang's album
Not really!!! on the older Mustangs specifically the 5.0s (fox bodied) this was a common problem! On the new edge Stangs Ford actually went with smaller diameter pulleys and i believe a stronger Amp alternator. Thats why you dont see such a big gain like you would on the Old 5.0s from a pulley swap. Ive had my FRPP U/Ds on my 99GT since 2000 and i have never swapped out my Altenator! As a matter of fact i had the original Motorcraft batterie til "05" before it had to be replaced
99GT 35th anniv. edition
01 Roush Stage 2+
04 SVT Cobra
Samsstang is offline Submit to Clesto
Questions about Underdrive Pullies... vonblinden22 4.6L V8 Specific 11 05-20-2011 01:25 PM
5.0 race only underdrive pulleys mb93gtconv Mustang Classifieds 0 12-07-2009 09:18 PM
Power Adders - mac underdrive pulleys for 01-04 gt DugDug Mustang Classifieds 0 09-29-2009 08:10 PM
Underdrive pulleys...The truth... crossland5 4.6 Mustang 16 12-04-2008 04:40 PM
Underdrive Pulleys Loadclr 5.0 Mustang 11 11-20-2007 04:33 PM
