Old 05-08-2007   #1 (permalink)
cfiiman's Avatar
09-14-2010 09:40 AM
Time Spent Online: 1 Hour 13 Minutes 32 Seconds
cfiiman's album
Possible first problem with my 96 Cobra Please help
Hey guys,
So today I was out playin around in the Cobra...Hit it a few times in 1st gear to about 4K RPM's nothing big just playin...Anyway sitting at a stoplight I smelled something weird, almost like gas but not quite, but definately a chemical smell, almost like gas rich exhaust or a cross between gas and exhaust smell is the best I can describe it...Anyway everything is perfect on my car so I just thought it was someone elses car until I smelled it at a parking lot and I knew it was me, "craaaaaaapppp" I thought....So it is not terribly strong, but noticeble if you are stopped in traffic...So I popped the hood and smelled around, I pinpointed the smell to be coming from the MAF...I don't know what the hell could be going on there but that is where it is coming from...Any ideas on what it is???...I am guessing the smell has to be coming down the intake and exiting there???...I don't get it, and like I said it isn't totally gas like you would smell from a leaky injector, it is weird like a cross between gas/exhaust...I can also smell it up at the top of the intake where the TB is but it isn't as pronounced there...I thought it was an injector but if you turn the car off the and smell directly over the injectors you can't smell anything, only at the MAF or when running at the MAF and the top of the intake/TB area...Please help!!!
Jason
-That's right I said Cobra!-
Proud owner of:
96' Cobra
90' 5.0 Paxton S/C Convertible
cfiiman is offline Submit to Clesto
Old 05-08-2007   #2 (permalink)
cfiiman's Avatar
09-14-2010 09:40 AM
cfiiman's album
Anyone?
Old 05-08-2007   #3 (permalink)
Re Member
Western KS
06-26-2011 06:57 AM
Time Spent Online: 1 Day 10 Hours 43 Minutes 36 Seconds
lostsohcs's album
Originally Posted by cfiiman View Post
Hey guys,
Jason
I am not sure about on a 96 Cobra specifically, but most hot wire MAF's superheat the hot wire that measures the air flow periodically to burn off dirt etc. that settles on the surface. Sometimes you get an oil smell, especially when using a K&N filter. If your lucky this is all it is.
lostsohcs is offline Submit to Clesto
Old 05-08-2007   #4 (permalink)
cfiiman's Avatar
09-14-2010 09:40 AM
cfiiman's album
Hmmm, that would be nice...It is weird b/c it just started out of thin air today, at a light and smelled it...I need to check into that, the smell doesn't smell like oil though, and I don't use a K&N...Does anyone know anything else about this superheating????...Would it help to remove the MAF and clean it and put it back or what????...Thanks,
Jason
Old 05-08-2007   #5 (permalink)
cfiiman's Avatar
09-14-2010 09:40 AM
cfiiman's album
Hey I found this on the web:
"Some symptoms of Mass Air Flow(MAF) meter failure is a rich or lean mixture depending on what is happening in the unit. The Oxygen Sensor will try to compensate for some of the activity through the computer but once the system goes out of preset bounds the "Check Engine" light will turn on. If the Throttle Position Sensor(TPS) is failing you may notice a flat spot while accelerating lightly away from traffic light and at cruising speeds. The check engine light may or may not come on depending on the programming in the ECM. If the Air Temperature switch fails the check engine light will turn on.
If the check engine light is not on and you are experiencing hesitation, flooding, hard starting, or the smell of gas, check the air filter, fuel filter, and plugs & wires. There are no sensors built in to the system that will tell if these parts are failing. If a cylinder is not firing as caused by a shorting plug wire the system goes full rich. It gives you great power but it greatly reduces your fuel economy of your vehicle and the converter gets very hot and can become damaged. "
I forgot to mention my car has a hesitation everytime around 3K rpms when getting on it, it just like stops for a second and then goes...Could my MAF be crapping b/c it is dirty or whatever and causing the rich "smell" condition like the above might suggest...I think maybe I should clean it tomorrow with carb cleaner and see what that does, both for hesitation and the smell...I looked at my air filter a while back and I didn't notice that it was that dirty, I'll check it again...Any other Ideas????...I'll let you all know...
Old 05-08-2007   #6 (permalink)
roush17
Guest
Posts: n/a
roush17's album
Do you have a midpipe on the car. I know this probably isn't it but a midpipe will make the exhaust smell very evident.
Submit to Clesto
Old 05-08-2007   #8 (permalink)
Friends: (25)
12-07-2013 02:00 PM
Time Spent Online: 1 Week 2 Days 12 Hours 48 Minutes 27 Seconds
damn never heard of that very strange.
Old 05-09-2007   #9 (permalink)
04-28-2018 09:44 AM
Time Spent Online: 4 Weeks 11 Hours 40 Minutes 24 Seconds
How old is your air filter jason?
Old 05-09-2007   #10 (permalink)
cfiiman's Avatar
09-14-2010 09:40 AM
cfiiman's album
Doug,
I'm embarrassed to say but I don't know, it was the one in the car when I bought it...It looked ok when I had it out but I wasn't really looking at it...
No midpipe, car is bone stock
I am gonna try to clean the maf and I will go get an air filter on the way home, man I hope this fixes it, I really don't want to take it to the dealer...The thing is when you pinpoint a smell you can usually see it you know...Like an injector will have fuel residue and stuff, but this is just a weird exhaust like/gas like smell right concentrated at the MAF...I don't get it...Any other ideas?...Could a dirty air filter cause this?....
Thanks guys,
Jason
96 Cobra problem update cfiiman 4.6 Mustang 14 11-13-2007 04:28 PM
about that problem svtsilversnake Engine Talk 3 10-04-2007 12:09 PM
has anyone had this problem svtsilversnake Engine Talk 13 10-02-2007 08:12 PM
96 Cobra Problem back :( cfiiman 4.6 Mustang 7 05-26-2007 12:01 PM
Cobra problem solved, bobbys97R need your help cfiiman 4.6 Mustang 11 05-23-2007 06:55 AM
